Buying a 96
Old Jan 22, 2008 | 11:51 PM
hondo21's Avatar
hondo21
Buying a 96
I'm looking at a 96 Explorer with a 5.0L V8, 2WD. Does anyone have any specific things I should look for on this year/model or watch out for?
Everything thats electrical works and there are no codes or check engine lights. It has 110K miles. I read where the 96-98 models with a V8 had the GT heads on them, so this should be good.
Lastly - what kind of mileage should it get 14-15 mpg?
Just looking for a reliable ride for my son, his 91 F-150 just blew the head gasket and we're gonna have to get something else quick. Sad to see that truck go!
Thanks,
Rob
Old Jan 23, 2008 | 12:25 AM
khadma's Avatar
khadma
Carpenter Local 745
Fix the 91!
It will probably be just as reliable as a 96 Explorer would be. How much is the 96?
I would also look it over really carefully.
I know trannys were problematic.
Old Jan 23, 2008 | 12:29 AM
85e150's Avatar
85e150
Far as I've seen/heard, V8-autos were ok.
Old Jan 23, 2008 | 07:44 AM
mason's Avatar
mason
Yes, no problems with the V8 transmissions just the V6s. No reason that the engine and motor can't go another 100k miles without major repair.
Mason
Old Jan 23, 2008 | 01:45 PM
marragtop's Avatar
marragtop
You should be able to get a pretty good deal if it's a 96 with 2wd, not 4wd. I suggest running the VIN thru CARFAX to verify the mileage and look for flood or accident damages.
Old Jan 24, 2008 | 08:01 AM
hondo21's Avatar
hondo21
Thanks for everyone's replies. I would fix the 91, but we've dumped so much money into it over 3 years, its time to get something else. That truck was part of the family though, so I may still keep it and work on it a little each month. Won't get much $$ for it now anyway.
I may look at a 92 Exp as welll with a 4.0L and 4WD. We had a 93 Ranger with the same set up and that baby ran like crazy!
Still, sounds like the 96 is a better way to go and it should get a little better mileage, although neither are that good.
I'll get the carfax ran too - that's a good one. The tranny shifts very well and the motor is smooth with no leaks on the ground.
Thanks!
Old Jan 24, 2008 | 08:08 AM
marragtop's Avatar
marragtop
I'd prefer the 96 over the 92. The Gen I (91-94) are noted for transmission and radius arm bushing problems. The Gen II has a better trans and no radius arm bushings. Addionally the Gen Is had rust issues in the rear dog legs and rockers, but you can certainly visually inspect that.
Old Jan 24, 2008 | 09:11 PM
andy79's Avatar
andy79
I have a '96 5.0 AWD. I like it a lot. I get 15-16 mpg.
Old Jan 30, 2008 | 06:47 PM
hondo21's Avatar
hondo21
Thanks everyone - I wound up buying the older Explorer. It's actually a '94 with 4.0L and 4wd. I couldn't pass it up because the previous owner took great care of it. I appreciate the tips on things to look for in this model and will take it to a dealerfor a check up.
FTE is a great site. I've used your sevice & advice for three years now on the 91 F-150 and our 93 Ranger. You've saved me a ton of money and gave us great projects to work on with my two sons.
MustangMatt96GT
20
Jul 3, 2013 06:53 AM
BigBlueOx
Aug 14, 2012 12:45 PM
strider3700
Aug 27, 2010 03:37 PM
clstrfbc
Electrical Systems/Wiring
Jan 6, 2005 11:03 PM
WhëëlMå1
Exhaust Systems
Jul 16, 2003 01:59 PM
