Will my Ranger pull this?
Old Jan 22, 2008 | 11:51 PM
brianca2's Avatar
brianca2
<TABLE class=tborder id=post1833126 cellSpacing=0 cellPadding=6 width="100%" align=center border=0><TBODY><TR vAlign=top><TD class=alt1 id=td_post_1833126>I have a 2007 4x2 xl ford ranger regular cab with a 2.3 4 cylinder with 5 speed manual. Can I tow this with out hurting any thing or wearing any thing out
11' 10"
Campsite length 16' 2"
Approx. travel height 53"
Weights
Unloaded vehicle weight (lbs.) 1,380
Approx. hitch weight (lbs.) 165
Gross vehicle weight rating (lbs.) 2,000
Cargo carrying capacity (lbs.) 620
Tank Capacities
Fresh water capacity (gals.) includes water heater 17
Other
Sleeping capacity 5-6
http://www.jayco.com/php/products/fl...146&mod_id=703
Thanks for any help or advice. It is appreciated
Brian N
<!-- / message --></TD></TR><TR><TD class=alt2 style="BACKGROUND: url(/forum/images/postbit.gif) #f7f7f7 repeat-y right top"></TD><TD class=alt1 align=right><!-- controls --></TD></TR></TBODY></TABLE>
Old Jan 23, 2008 | 01:21 AM
RangerPilot's Avatar
RangerPilot
Well with the four-banger it's not gonna be fast, but yeah, it'll pull that. It'll even be acceptable to do it with just the bumper and not a weight-distributing hitch (though I always recommend one).
Your owners manual will contain the detailed charts for engine/tranny/rear gearing specific towing weights, and it'll probably spec some unrealistically low number for the 2.3L/manual combo to keep Ford from having to replace clutches because people couldn't drive a manual while towing. If you can handle the clutch pedal just fine, have no fears.
Old Jan 23, 2008 | 08:30 AM
sfcwoodret's Avatar
sfcwoodret
Yes, it will pull it.
Old Jan 23, 2008 | 08:31 AM
pawpaw's Avatar
pawpaw
Welcome to FTE.
I see your in BC, so if your going to be tugging in the mountains, or for long high speed tows, be sure to follow your owners manual towing instructions closely.
Seeing as how your going to be working your engine pretty hard & if you'll be tugging in the mountains, or for long high speed tows, maybe consider opting for a good synthetic crankcase lube, that can take the heat & high engine rpm's you'll be giving it.
Don't know if you opted for the "payload, package-2, or a tow package, but both of those might be worth considering, as they will improve handeling, with that much tongue weight on a light truck.
Your Dealer should be able to order & or install them, if you choose to add them.
I also opted for the class-3 factory frame mounted hitch & bought a "cushioned ball mount", by "Convert-A-Ball", at my local farm supply store, it'll realy round off the jerks & jars to the drive line while towing & your driveline & you, sure will appreciate that!!!!
With the tow & payload packages & a cushioned ball mount, my towing in the mountains & control on the highway have been plesant!!!!
Be sure to keep you tires aired up!!!!
Just some more thoughts for pondering.
Old Jan 23, 2008 | 12:57 PM
fordboy_52's Avatar
fordboy_52
i second rangerpilot
Old Jan 23, 2008 | 01:03 PM
bigrigfixer's Avatar
bigrigfixer
The Pacifier
Yeah it'll pull that. I'd at least get a class 3 receiver though, no need to bend a bumper.
On a side note, where did you find that? My wife and I have been looking for a lightweight tent trailer for months. She keeps getting sucked in to the big and heavy 4000 pound ones.
Old Jan 25, 2008 | 09:21 PM
brianca2's Avatar
brianca2
Well I went and bought a 2008 jayco 806. I am getting a class 3 hitch installed. Thanks for all your help
Old Jan 26, 2008 | 08:40 AM
99F150's Avatar
99F150
You will be fine, and get good mpg while towing to boot.
I have a 1999 supercab with the less powerful 2.5L 5speed and i pull a 12' starcraft tent camper with a slide out dinnette and roof air. The camper has been weighed at 3000 lbs. I tow at no more than 65 mph for safety and get 18-19 mpg towing.
Old Jan 26, 2008 | 11:24 AM
mjpennella's Avatar
mjpennella
Thumbs up
I own a 1999 Ford Ranger XLT 4x4 3.0L and I have pulled a 750lb trailer with two 1000lb commercial zero turns. Your truck being new,it should pull it with no problem.
