Sponsored by: Real Truck
Airbag Steering wheel removal
Old Jan 24, 2008 | 02:25 AM
cartmanea's Avatar
cartmanea
Thanks! So the crash sensor always needs to be replaced? How about the one for the passenger side, is it okay since that side was deactivated by the dash switch?
Old Jan 24, 2008 | 08:06 AM
F350-6's Avatar
F350-6
Originally Posted by Topbob
Appreciate the info re: airbag/steering wheel removal; as others have said, good work.
Question: does steering wheel have a master spline or should it be marked for alignment before removal? Thanks.
My experience all comes from bad judgement; am still waiting for good judgement
I've never indexed the wheel pulling it off. If your steering wheel is straight now, then just make sure you have the steering wheel and tires straight ahead before you pull it off. When you put it back on, just put the steering wheel back on straight.
I usually drive forward a few feet making sure the tires are straight instead of trying to straighten things up while parked to make sure there's no pressure in the steering components that might try and push the wheels one way, but that's just me.
F350-6's Avatar
F350-6
From what I read, the crash sensor has to be replaced in case of deployment. Since the passenger bad did not deploy, that one should be fine.
Old Jan 24, 2008 | 08:08 AM
vettdvr's Avatar
vettdvr
I always mark the shaft to wheel to get it back straight. I have never seen one w/o the mark but I always use a marker to highlight it so the dummy working on it won't forget. I have never put one on incorrect.
Old Jan 26, 2008 | 03:47 PM
F350-6's Avatar
F350-6
In case it isn't obvious from the pics the cruise buttons just slide out towards where the horns used to be. I found this link about repairing the buttons and thought I would include it here.
https://www.ford-trucks.com/forums/6...3l-diesel.html
Old Mar 5, 2011 | 12:08 AM
SpringerPop's Avatar
SpringerPop
Yes, it has a master spline for replacement alignment.
It will only go back on one way.
Oooops! Followed a link to this thread, read it, and didn't notice the date!
Pop
Old Jul 13, 2017 | 08:05 AM
kwdaye's Avatar
kwdaye
replace the steering wheel lock plunger
Originally Posted by F350-6
12) To remove steering wheel unscrew the torx screw in the center of the steering wheel.
13) Using a 2 jaw puller remove the steering wheel.
14) As the book likes to say “To install, reverse procedure”
<o> </o>
Let me know what I left out or if anyone needs more info.
Do you have any videos on how to replace the steering wheel locking plunger for a 2003 F250?
Thanks,
Kevin
Old Jul 13, 2017 | 09:04 PM
F350-6's Avatar
F350-6
No videos. I don't have an account to post them.
By locking plunger, do you mean the cylinder for the key, or the long bar with gears on the bottom that activates the whole thing as you turn the key. I got to replace the long bar with the teeth that is what the key turns on my wife's truck. I'll have to see what pictures I have of that if that's what you're looking for.
Old Jul 14, 2017 | 06:17 AM
kwdaye's Avatar
kwdaye
Yes, the long bar with gears on the bottom that activates the whole thing as you turn the key.
Old Jul 14, 2017 | 07:42 PM
F350-6's Avatar
F350-6
It's time consuming but not that hard to do. I don't have the pics in this computer. I'll have to look through some back ups and see if I can find some photos.
I used to have these photos uploaded to my user gallery, but they decided to get rid of those and all the photos stored in them along with it. They've now moved on to albums or some such, but what's the point if that will change too without migrating all the old photos.
So you know how to get the steering wheel off, do you know how to remove the steering column cover? It's just 3 phillips screws in 3 of the 4 holes in the bottom side of the cover. Stick a screwdriver in there and you can remove them by feel. The bottom and top half of the cover separate and come off. To remove the key cylinder, there's a detent button (silver bb looking thing inside a hole) under the key cylinder. Stick the key in the ignition and turn to run, push the bb button, and pull the ignition cylinder out.
Then take things apart from there to get to that gear piece. I'll look for pictures and see what I can find.
Old Jul 14, 2017 | 08:01 PM
kwdaye's Avatar
kwdaye
Ok, thanks for the info and yes I know how to get the covers off and the tumbler/ keys assembly out. I will work on it and let you know how it goes
Old Jul 18, 2017 | 12:54 PM
kwdaye's Avatar
kwdaye
I have it all taken care of, thanks
Old May 1, 2021 | 10:02 PM
  #28
M C's Avatar
M C
<o> </o>
What size torx?
Old Dec 31, 2022 | 01:13 PM
  #29
Mjlennon's Avatar
Mjlennon
3rd Gear
Originally Posted by M C
What size torx?
T-50 torx.
Old Jun 7, 2023 | 08:30 AM
  #30
John in OkieLand's Avatar
John in OkieLand
Still useful info,
helped me out today
