Sponsored by: Auxito
Does'nt like to warm up
Old Jan 22, 2008 | 04:33 PM
dahn's Avatar
dahn
99 F150 V6 129,000 miles just bought this truck.Starts up in the morning fine go out after warming up for 15 min.Engine idling low abought to die come to stop light half to two foot it.If I turn it off and restart it,it seems to help and runs ok. Check engine light say misfire number 4 cylinder.Is that the one in the front on the drivers side or passenger Hayes manual confusing me.Could this be an EGR problem?Has anyone had this problem? I'm going to start with the spark plug change first.thanks
Old Jan 23, 2008 | 06:29 AM
projectSHO89's Avatar
projectSHO89
Do the plugs. Inspect the old plug from #4 (driver's forward) carefully.
Clean or replace the IAC valve.
Reset the computer (disconnect battery while servicing will do it).
Steve
Old Jan 23, 2008 | 04:23 PM
dahn's Avatar
dahn
Thanks Steve,I seen when searched low idle alot of people said they had problems with the IAC.Some said they just cleaned out the carbon deposits and put it back in and it worked ok.I'm going to put the plug in and check the IAC this weekend. THANKS
Brawl
1983 - 2012 Ranger & B-Series
13
Aug 22, 2006 07:21 PM
F-150kekec
Modular V8 (4.6L, 5.4L)
Sep 25, 2004 12:34 PM
78f150mudder
Sep 5, 2004 08:18 AM
racingdeathwish
Dec 21, 2003 12:25 AM
racingdeathwish
Dec 19, 2003 10:23 AM
