C6 swap?
Old Jan 22, 2008 | 02:34 PM
64blue's Avatar
64blue
C6 swap?
I can't find a good rebuilt c6 nearby. Are there any alternatives for my 1977 351M. Can a AOD be used?
Old Jan 22, 2008 | 06:18 PM
cjstang32's Avatar
cjstang32
You're a little limited to what will bolt up. 351M/400s has the same bellhousing bolt pattern as a 460. They didn't make AODs with that bolt pattern. If you're thinking overdrive, you'll have to go E4OD. Unfortunately, it's processor controlled. There are companies that make stand-alone processors for E4ODs but they're very pricey. The only other option would be an old FMX but they're a lot more rare than a C6.
Old Jan 29, 2008 | 07:37 AM
davemccorkle's Avatar
davemccorkle
Everyting you need
I have everything you need! I have a good C-6 with tork converter, teering column, peddle cluster, cooler, etc. I am in the st. louis area though. Give me a call.
David
314-578-4077
