302 id help
Old Jan 22, 2008 | 01:19 PM
td2's Avatar
td2
302 id help
what do the numbers on the paper tag on top of my valve cover represent. numbers are c with a 1 under it, then ck 348 ab. has e,9 scratched out at bottom has numbers 2-54d-r10. the vin tells me that this is not the motor that came in my 1986 f-150 4x4 just trying to get a little info about it thanks
Old Feb 13, 2008 | 06:04 PM
classicranger's Avatar
classicranger
The casting numbers are above the starter on a flat spot on the block, this may tell more.
http://www.classicmustang.com/casting_numbers.htm
Old Feb 13, 2008 | 09:50 PM
baddad457's Avatar
baddad457
Just gobbletey gook info used in production. The casting numbers and date code would be more helpful.
