460 Squeek
Old Feb 24, 2002 | 07:00 PM
whizbang's Avatar
whizbang
460 Squeek
I've got a 79 bronco with a 460. I just put a cam, lifters, timing chain, and valve springs. Now I've got a sqeek coming from the vavle covers. I took the drivers side valve cover off and ran the engine and no oil was getting to the head. I it run for a few minutes to make sure. I've got good oil pressure (about 75psi start up cold and 45psi warm. I've got ajustable rockers on it to if that helps. Please help me out if you can.
Old Feb 25, 2002 | 11:52 PM
Superdave's Avatar
Superdave
460 Squeek
Is this oil pressure with a mechanical gauge, and from the top back of the block? Is there no oil on the other head?
Old Feb 26, 2002 | 05:19 AM
whizbang's Avatar
whizbang
460 Squeek
yes the gauge is mechanical at the back of the block and there is oil at the other head.
Old Feb 27, 2002 | 08:43 AM
dre's Avatar
dre
460 Squeek
Since you just installed a new cam.
Make sure your push rods are not clogged up with
assembly lube.
Dre'
1978 F-150, 460ci(750cfm,Edelbrock Performer,Dynomax Ceramic Coated headers,etc.)Auto-C6,373:1 - 9" Posi.
Old Feb 27, 2002 | 09:48 AM
77_f250_460's Avatar
77_f250_460
460 Squeek
CurtSD
Modular V8 (4.6L, 5.4L)
Aug 26, 2014 04:17 PM
Dirtrag99
Mar 23, 2014 04:13 PM
Rusty_Old_F250
Oct 18, 2010 08:22 PM
Officermt23
Feb 24, 2010 01:56 AM
