piston selection
Old Feb 16, 2002 | 11:33 AM
SKID's Avatar
SKID
piston selection
Can anyone tell me who makes a good flat top piston?
I want to run around 11:1 cr
I have a set of dove-A heads that are ported and polished
and I`m going to run a comp cam either 34-342-4 .605 .605 lift
or 34-343-4 .640 .640 lift
this is for a race engine and eventually may run nitrous.
Old Feb 20, 2002 | 12:38 AM
ex91's Avatar
ex91
piston selection
i can't help but when are you planing on runing juice, i thought that only dodges needed that.
Old Feb 20, 2002 | 09:05 AM
TBirdGuy's Avatar
TBirdGuy
piston selection
Whatever you select for a brand, MAKE SURE, MAKE SURE you get forged!!
If you are planning on running nitrous in the future, you will NEED them.
TBirdGuy
Old Feb 26, 2002 | 09:02 PM
notlistedsite
Guest
Posts: n/a
piston selection
Does anyone but Venolia make pistons? Not in my world!
Old Feb 28, 2002 | 09:02 PM
mavman's Avatar
mavman
piston selection
SRP is the way to go, they're not "that" bad expensive, they are forged, and they dont weigh near as much as trw's. You probably need just a flat-top with 1 valve relief for your application, cause with the small chambers you dont need a dome piston. I just put a 393 together, and the trw's would work, but the valves would hit the pistons with the .792 lift cam. The srp's dont hit at all..in fact, srp's are actually made by JE. Just my $02.
Old Mar 1, 2002 | 12:48 PM
bigsnag's Avatar
bigsnag
piston selection
