1978 - 1996 Big Bronco
Rear End Tag
Old Jan 22, 2008 | 12:19 AM
toolman's Avatar
toolman
Rear End Tag
So, not wanting to beat a dead horse...but I'm having some rear end vibration and found a u-joint on it's way to the afterlife. I knew the rear end had been swapped out, so I sprayed and scraped the tag hoping to ID it. Yhere were two lines of text stamped into it.
The upper one read " S318d "( ok so there were some spaces but my wife was making notes for me and scrunched them together ) The lower line read
" 3 50 9 5K01 "
Is this an open 9" rear end with a 3.50:1 ratio ?
Do the other numbers mean anything ?
Thanks !
-Scott in Spokane
Old Jan 22, 2008 | 12:22 AM
Surge08's Avatar
Surge08
Means you have a 3.50 gear ratio
Old Jan 22, 2008 | 08:57 AM
toolman's Avatar
toolman
What I'm really looking for at the moment is what rear end it is. The auto parts store lists 2 different U-Joints ( one being for the 8.8" and the other being for the 9", with one being slightly larger than the other ) Also, it was my understanding that the 9" had a removable 3rd member and the 8.8 had an inspection cover.
THANKS !
-Scott in Spokane, Wa.
Old Jan 22, 2008 | 11:48 AM
Surge08's Avatar
Surge08
The 9 in the take mean 9 inch rear. If it was a 8.8 it would say 350 8 8 5k01
Old Jan 22, 2008 | 12:27 PM
andym's Avatar
andym
An 8.8" was never available with a 3.50 gear ratio. You definitely have a 9".
The year would also help confirm this, as the 8.8" started in 1983 and was phased in until about 1986.
Old Jan 22, 2008 | 12:38 PM
helirich's Avatar
helirich
As you said, the 8.8 has a tin cover on the back. The 9" has a third member.
Old Jan 22, 2008 | 08:31 PM
justshootme84's Avatar
justshootme84
" 3 50 9 5K01 "
Thanks !
-Scott in Spokane
Like the others have said, that tag says it's a Ford 9", 3.50:1 open gears ( no factory L/S). The other numbers are build date and BOM numbers (bill of material), used when you need to order parts like gears or axle, bearings, etc. JSM84
Green Griffin 420
18
Sep 27, 2023 12:40 PM
clydes 74 ford
15
Nov 6, 2017 11:40 PM
DDDDDMorgan
Sep 11, 2016 10:57 AM
sonny1965
Apr 17, 2014 04:26 PM
johnson2007
Aug 18, 2009 02:59 PM
