sheet metal swap candidate
Old Jan 21, 2008 | 09:07 PM
bwilliams7527's Avatar
bwilliams7527
Lightbulb sheet metal swap candidate
There's a guy selling a 79 f-250 in my area for $500...2wd...351M, 4 spd granny. I'm going to look at it Wednesday hopefully. I was thinking about doing the sheet metal swap from my 66 over to this chasis to get the power disc, steering, etc. I've got a buddythat's a pro. welder that can move the rear axle for me. I was curious of some of the veteran's thoughts on the 351M. I'm hoping I might be able to get it for 350 or 400.
Old Jan 21, 2008 | 10:13 PM
William's Avatar
William
Unless you are building an F250, wait for a better candidate. The F250 frame will work and you can swap in later F150 disk brakes, I Beams and your original differential. You could even use the floor pan and bed bottom if you have the welding skills. But the simplest swap will be to a F150 with the engine you prefer and disk brakes and power steering options.
nineteensixt5f100
Mar 7, 2015 07:45 PM
Ripcity
Oct 12, 2013 09:45 AM
78ford351m
16
Nov 18, 2008 07:15 PM
Pudmullet
19
Oct 20, 2006 10:27 PM
