1966 250 diesel
Old Jan 21, 2008 | 07:42 PM
64blue's Avatar
64blue
1966 250 diesel
Can a 7.3L diesel be put into a 1966 f-250?
Old Jan 21, 2008 | 07:50 PM
garbz2's Avatar
garbz2
Yes
Garbz
Old Jan 21, 2008 | 07:51 PM
chrono4's Avatar
chrono4
anything can be put into just about anything. The real question is whether you have the fab skills and access to the tools to do it. You will more than likely need to beef up the front suspension to handle the weight, and maybe clearance a few things here and there.
Old Jan 21, 2008 | 07:55 PM
427SOHC's Avatar
427SOHC
64blue,
If you go through with it make sure you post pictures in your gallery so we all can see.
Would be helpful for others to see that would want to do it.
Old Jan 21, 2008 | 11:24 PM
sgtofcdn's Avatar
sgtofcdn
I know people are going to hate me for saying this, but I read about a guy that put in a 5.9 cummins turbo diesel with a (important part) hydraulic, not the electronic, allison transmission. Besides the mounting, fuel pump/tank, electrical, the only serious physical change was he lowered the front beam (under the front of the engine) 2 inches. Basically he cut the beam then moved it down and welded it. Apparently the 6 cylinder cummins, although heavy, wasn't a problem. Guys have mounted heavy plows on the front which were about the same extra weight, where as the Ford and Chevy V8 diesels are heavier. Don't get me wrong...the Ford diesel is awesome, but huge. Of course when I heard this, it was about 3 years ago...that being said. Some of the experts here could probably give you the specs on all types of the latest diesels, including weight and size.
Old Jan 22, 2008 | 03:50 AM
jowilker's Avatar
jowilker
64, Have you considered moving the sheetmetal over the the chassis with the diesel?
It might be easier, than replacing the gas setup.
John
Old Jan 24, 2008 | 09:22 PM
64blue's Avatar
64blue
I've been thinking about it. What if I were to set a 66 body on top of a 1994 E-350 chassie and drivetrain. The specs on the E-350 are Length-138.00 Front width -69.4 Rear width - 73.2. Anyone got the specs on the 1966 250?
LDCF250
147
Oct 9, 2017 09:19 AM
taz6131965
Jul 12, 2016 12:34 PM
bguy
Sep 19, 2014 05:49 PM
Steves Ladybird
56
Sep 20, 2012 05:14 PM
FORD1966
Oct 16, 2009 11:42 PM
