Serpentine belt conversion
Old Jan 21, 2008 | 06:55 PM
slow351w's Avatar
slow351w
My 351w has the old v-belts, i would like to convert it into a serpentine belt any ideas on what i would need to get to do this, my donor motor is a 1989 302
Old Jan 21, 2008 | 08:44 PM
Archion's Avatar
Archion
Veteran: Marine Corps
Waterpump, all brackets, maybe timing cover, basically everything off the front of the block.
Old Jan 21, 2008 | 10:26 PM
scrapyardking's Avatar
scrapyardking
Wht would you want to make the swap in my Opinion the v-belts are the way to go.
Old Jan 22, 2008 | 08:10 AM
slow351w's Avatar
slow351w
My a/c bracket is custom made, my crank pulley is bent and throws the a/c belt, which in turn throws evert other belt above 3K rpm and im tired of it
Old Jan 22, 2008 | 09:15 AM
Franklin2's Avatar
Franklin2
It may be easier to get a v-belt setup from the junkyard. You will have to change all the pulleys on the accessories(you need a special puller for the power steering pump), all the brackets, and also the waterpump(it turns backwards on a serpentine system). The serpentine systems in my experience are noisy too.
Old Jan 22, 2008 | 09:50 AM
Sycostang67's Avatar
Sycostang67
There's a good chance the brackets from that 302 will not fit the 351 since the block is taller. If any of them bolt to the front of the motor and the heads, they wont work.
Justin Jones
Feb 11, 2018 10:06 PM
jack odom
Oct 18, 2013 10:52 AM
jack odom
Sep 11, 2013 11:08 AM
ozblitz
18
May 13, 2010 08:46 PM
airharley
Feb 3, 2002 12:39 PM
