Loud Noises!!!!
Old Jan 21, 2008 | 04:03 PM
dlgentry's Avatar
dlgentry
Exclamation Loud Noises!!!!
Well, My Buddy Has A Mid 90's F 150 Flare Side 4x4 With A 6 Banger. Here's The Deal. There Is A Loud Squeaking Noise Coming From What Sounds To Be The Back Of The Tranny Were It Connects To The Drive Shaft. All U- Joints Are Brand New. Anybody Got Any Ideas Before The Trannt Gets Pulled, Thanks In Advance!!!
Old Jan 21, 2008 | 08:27 PM
njtinman2's Avatar
njtinman2
how new are the ujoints and were they neapco brand joints
Old Jan 21, 2008 | 09:32 PM
89frankenford's Avatar
89frankenford
have you looked at the slip joint on the driveshaft(if it has a 2 peice driveshaft)
Old Jan 21, 2008 | 11:26 PM
NeXtras's Avatar
NeXtras
they dont have 2 piece joints (mine doesnt) i dont think that varries engine to engine as i have a 302 and not the 300
check your u joints again, and make sure you didnt put them in dry cant tell you how many times ive seen that...
check wheel bearings, sounds carry weird sometimes, and you DONT wanan go through what i went through, TRUST ME
Old Jan 22, 2008 | 05:12 AM
toddol1971's Avatar
toddol1971
trans mount?
Old Jan 22, 2008 | 05:13 AM
toddol1971's Avatar
toddol1971
If its a stick shift maybe the throw out bearing is squeaking?
Old Jan 22, 2008 | 04:33 PM
dlgentry's Avatar
dlgentry
The Sqweeking Started After He Drove It 8 Hours Back From Ohio. We Thought It Was The U-joints, Replaced With Brand New From A-zone. They Were Well Coated With Wd Before Installed. Same Issue After They Were Put In. It Sounds Like Its Coming From The Tranny But I Guess It Could Be The Wheel Bearings. Easy Enough To Check. I'll Keep You All Posted. Thanks Again For The Help.
Old Jan 22, 2008 | 05:20 PM
87white250's Avatar
87white250
did you grease the nipples on the u-joints? I have done that before and it results in that same annoying little squeek....
good luck
Old Jan 22, 2008 | 07:01 PM
njtinman2's Avatar
njtinman2
you said ujoints but does it have a cv section?
Old Jan 23, 2008 | 06:35 PM
dlgentry's Avatar
dlgentry
Well It's Not The Tranny Brace, Still Holding Strong, Didn't Grease Nothin Just Hit With Wd, On The New Ones There Is No Zerks. What Do You Mean Cv Section????
Old Jan 23, 2008 | 06:49 PM
Skandocious's Avatar
Skandocious
He means a slip yoke with a carrier bearing like my driveshaft has:
Old Jan 23, 2008 | 07:10 PM
njtinman2's Avatar
njtinman2
no would be two ujoints back to back with a centering section
Old Jan 23, 2008 | 08:20 PM
dlgentry's Avatar
dlgentry
Doesn't Have A Centering Section, Solid All The Way Back.
Old Jan 23, 2008 | 08:26 PM
Skandocious
They didn't offer true CV sections like that on these trucks. At the very most they'd have a 2 piece shaft like mine.
Old Jan 23, 2008 | 08:27 PM
kcb37's Avatar
kcb37
If they don't have a grease zerk the best way to put them in is to pull the caps and put some grease in them, then put the caps back on. WD-40 would eat up any grease that was in them to begin with and eventually wear away, run out, or dry out.
I would pull the u-joints out/apart and put some grease in them.
