Loud Noises!!!!
Old Jan 23, 2008 | 08:30 PM
Skandocious's Avatar
Skandocious
a) Joints without a zerk and pre-greased and don't require any more than they have when you buy them.
b) WD40 is not a lubricant, it's a penetrant. You should NEVER use WD40 to lubricate something like a bearing or a ujoint.
c) Where in the heck did you spray WD40?!
Old Jan 23, 2008 | 08:44 PM
kcb37's Avatar
kcb37
Skandocious is right. They should be pre grease.
But I will say this to Skandocious. WD-40 isn't a penetrand it is a water displacement.
That is where the name actually came from. Water Displacement, and it took 40 formulas (tries) to get that Formula.
Just saying.
Old Jan 23, 2008 | 08:46 PM
Skandocious
True that it does displace water, but yes it is in fact a penetrant.
http://www.wd40.com/Brands/pdfs/msds-3in1pro_penet_spray.au.pdf
Notice the title at the top
Old Jan 23, 2008 | 09:22 PM
kcb37's Avatar
kcb37
Okay, jeez.
Hey if you take out the part where I said it's not a penetrant, then were both right.
Guess you really do learn something new everyday.
Old Jan 23, 2008 | 09:27 PM
todd31277's Avatar
todd31277
Originally Posted by kcb37
If they don't have a grease zerk the best way to put them in is to pull the caps and put some grease in them, then put the caps back on. WD-40 would eat up any grease that was in them to begin with and eventually wear away, run out, or dry out.
I would pull the u-joints out/apart and put some grease in them.
nailed it. wd-40 and 8 hour drive. probably left all the grease in Ohio
Old Jan 23, 2008 | 09:30 PM
kcb37's Avatar
kcb37
Not to keep adding, but WD-40 is great if u use it right. (right place, right thing).
U-joints aren't one of them.
Old Jan 24, 2008 | 07:48 AM
toddol1971's Avatar
toddol1971
u joints are cheap enough that if you pull them out put new ones in.
Old Jan 24, 2008 | 04:20 PM
dlgentry's Avatar
dlgentry
Thanks To All For The Info. Lesson Learned......use Wd For What It Was Designed For....not U-joints!!!
