Brake booster question...
Old Jan 21, 2008 | 07:52 AM
Six Niner's Avatar
Six Niner
I have the small diameter brake booster on my 69...its going bad and I need to replace it. I have a large diameter booster off of a 78 or 79 and wondered if it would require any mods? Thanks for the help.
Old Jan 21, 2008 | 11:52 AM
blue68f100's Avatar
blue68f100
I don't think there interchangeable. The 69 mounts to the bracket while the 79 mounts directly to the firewall. Somewhere in late 70's is when they went to the firewall mount. The ends may be different too. Numbers will know for sure which years fit.
Old Jan 22, 2008 | 07:58 AM
Six Niner's Avatar
Six Niner
thanks for the info, hopefully he will chime in...
Old Jan 22, 2008 | 10:56 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
1969 F100's originally used two different boosters.
Ford later replaced the early booster with the late one = 1969/70 F100 = C9TZ-2005-D
1973/79 different boosters...disc brakes only after 1972 (except on 4WD 1973/75).
1969/72 F100 = C9TZ-2005-D
1973/76 F100 = D3TZ-2005-A / 11.46" DIAMETER
1977 = D7TZ-2005-A / 11.00" DIAMETER
1978 & 1979 DIFFERENT AGAIN.
Old Jan 22, 2008 | 12:25 PM
Six Niner's Avatar
Six Niner
Well...bummer I guess that answers my question, thanks for the response though. Off to the parts store we go!
Old Jan 25, 2008 | 06:09 AM
Take2's Avatar
Take2
I have a 76 booster on my 67... I am using the brackets that came off the 76 but everything more or less bolted right up. I will tell you if you are using the pent roof valve covers on an FE it's a close fit but it works!
Hope it helps (I think I have an underhood shot in my Gallery)
David Sellars
svolpone
Mar 15, 2017 01:13 PM
Nitro901
38
Sep 17, 2016 06:53 PM
wiltshire46
Oct 6, 2015 06:19 PM
yak
Mar 1, 2010 08:24 PM
