Have a 1990 aerostar with a 4.0l engine and when you turn the key on the stereo pops and the inside lights flicker with the pop. The stereo is off and the face plate is out and it still pops through the speakers. When you start it you hear the engine through the speakers. The check engine light comes on and off from time to time. When plugged into the computer to get a code the light goes out and the motor revs up for a minute then goes back to normal until you unplug it. Went through and replaced the coil pack this weekend. Did not help.
How did you hook up the stereo? if you chopped up the factory harness that could make the weird noises. sounds like something is shorting out. I know i had issues when i first hooked up a cdplayer in my dad's aero, and i cut up the factory harness's, i had issues with the speakers sounding bad and not working right.
best to add a stereo with a 12v relay powered directly from the battery and switched with ignition or added switch.
12v wiring on Aero will not handle most add on stereos
also solves most of the alternator ignition engine computer noise problems.
always ground stereo on chassis metal as close to stereo as possible. never back to battery.
what do you mean relay? how would you hook this up?
The Areo that Allen Jr is talking about is my wifes, the stereo has been the van for years without any noise. The problems with it started with a random CEL with NO codes, it has been check by 5 differant shops and differant computers. The popping and it had a buze, that he is talking about started when the van died while it was running down the road at 60mph and started up again on it's own. This past weekend we changed the coil pac, battery and the spark plugs. I still have the popping in the stereo that makes the lights blink, and as of yesterday, still getting a random CEL.
Question, what kind of plugs and wires do you have. The reason I ask is that non-OEM wires may not have the proper noise suppression. If the wires are emitting too much electromagnetic noise, it may be audible on the stereo, and it can also feedback into the computer causing erratic behavior. If you are not using Motorcraft wires, or the wires are really old, I would suspect they may be involved.
They are aftermarket wires and about one year old, and the noise just started. My son fond a loose plug on the alt. and it seems to be ok as of last night, will see today, my wife took it to work today.
bertha,
The static suppressor is mounted to the coil pack frame but the lead wire is grounded by one of the coil pack hold down bolts - if memory serves. In those tight confines, its easy to overlook a small, dark, wire lead like that. There is only a single lead, so you can reach back with one hand and finger trace the lead to its mounting point.
Thanks, it is VERY tight up in there. My wife call to say that it is running good, but has a small buze in the stereo, so I be thinking you are right about this.
So does the interference go up & down with engine revs or does it stay constant? .........is it there ALL the time.
Sounds like you could have a bad ground connection somewhere.
Do all of your electricals work correctly ?
bertha,
After pondering this advice some more, I think I am confusing the Aerostar setup with a recent repair on a Contour which does have a lead wire grounded to a coil pack bolt. I think on the Aerostar it is just the metal suppressor body mounted to the coil pack frame (which grounds it) and only a wire connector. Sorry for any confusion.
