tune up
Old Jan 20, 2008 | 10:10 PM
jake 95psd's Avatar
jake 95psd
tune up
I just did a tune up on my 99 exp repalced all 8 plugs and boots in about 2.5 hrs. The #3 plug was loose I was able to take it out by hand. Just wondering if plug blowouts happen after you replace plugs or before or both.
Old Jan 20, 2008 | 10:49 PM
anfo's Avatar
anfo
both, did that #3 screw in and tighten ok? sounds like that one was on its way out.
Old Jan 20, 2008 | 11:01 PM
antony25's Avatar
antony25
#3 is the most common blow out.
Old Jan 21, 2008 | 08:38 AM
Gage2502's Avatar
Gage2502
Jake 95PSD, it only took 2.5 hrs for the plugs? Thats really fast I though it takes about 6-8 hrs? Was it hard, I was going to change the plugs on my 2000 Expedition 5.4
Any tips?
Thanks ~Gage~
Old Jan 21, 2008 | 09:40 AM
jake 95psd's Avatar
jake 95psd
When I first took a look a it I thought it would take a lot longer than it did. I started on the passenger side front and worked back. Just used a plug socket and 2 or 3 extensions. I used a 7mm nut driver to remove the COP. #7 was the toughest to get the COP off. Olny had to use one swivle with 2 4in extension to get to #4. Other than that just had to take time and stay cool.
Old Jan 21, 2008 | 09:44 AM
jake 95psd's Avatar
jake 95psd
anfo
the #3 screwed in and tightend up just like the rest of them. I didn't use a torque wench to tighten. Just hand tight and then a half to three quarters of a turn. Didn't want to over tighten
Old Jan 21, 2008 | 10:43 AM
buzzard's Avatar
buzzard
I've followed the "blow-out" problem for years. Based on my readings, most blow-outs seem to be a result of improper installation (ie crossthreading) of new plugs.
Gage, if you have a decent set of socket extensions, the complete job shouldn't take more than 3 hours. I actually thought the job was much easier than I anticipated. The hardest part for me was being able to reach all the plugs inasmuch as I have a 4x4 with larger tires.....I should have flattened my front tires before starting.
Old Jan 21, 2008 | 11:46 AM
kailor's Avatar
kailor
jake 95psd, 2.5 hours is great. It took me 5-6 hours.
Gage2502, ALWAYS ALWAYS ALWAYS use a length of vacuum hose to get each new plug started in the hole. This prevents cross-threading.
Old Jan 21, 2008 | 01:30 PM
happycamper116's Avatar
happycamper116
I guess I just don't get the vaccum line thing. Use it in what way? sorry to be so dumb, just don't get it.
Old Jan 21, 2008 | 02:06 PM
kailor's Avatar
kailor
happycamper116, let me try to explain. Take a piece of vacuum line that is big enough to slip over the tip of a spark plug and stick it on the end of the spark plug. The wells for these plugs are very deep. Stick the plug and hose (as one piece) into the spark plug well. Turn the hose (a little tricky if hose is not exactly straight) to start the plug into its hole. If the hose does not turn, the plug is trying to cross-thread itself. Back the plug a turn or so to get it free. Try again. You will know when you have it right because the hose will turn fairly easily. You cannot transmit enough force along a hose and force a spark plug to cross-thread itself. With a normal socket and extension, you don't have that "delicate feel" for starting the spark plug into its hole. After you get the spark plug started (the hose will no longer turn easily), pull on the vacuum hose to remove it from the spark plug. This way you don't cross-thread a spark plug AND your spark plug socket won't be stuck on the end of the spark plug. Finish tightening the plug with a ratchet, extension and socket.
Old Jan 21, 2008 | 02:12 PM
jake 95psd's Avatar
jake 95psd
I also used a piece of vacuum hose to start the plugs
Old Jan 21, 2008 | 03:10 PM
Gage2502's Avatar
Gage2502
Great tips guys, I think I might give it a try in spring.
~Gage~
Old Jan 21, 2008 | 03:58 PM
happycamper116
Thanks Kailer, I think I got it now. might have to give this plug change thing a try. thanks again, happycamper116
Old Jan 21, 2008 | 04:12 PM
kailor's Avatar
kailor
Isn't this a GREAT forum?
Old Jan 21, 2008 | 06:20 PM
vze2sgxa's Avatar
vze2sgxa
Brothers, here is a link to my plug change experience, very long winded and written post, but I was glad I did the job myself, and here's why:
https://www.ford-trucks.com/forums/6...ml#post5499863
Gage, you will be fine doing this if you just take your time and follow our advice... next time I change the plugs, it should be quicker, ....
