Starting problems?
Old Jan 20, 2008 | 08:37 PM
beersy50's Avatar
beersy50
Starting problems?
I have an 89 F-350 with the 7.3, I don't run it on a daily basis yet, usally once or twice every two weeks. The block heater is always pluged in in and the tank is mostly full, it does sit on a slight incline. My problem is that it starts very hard, it almost acts like its out of fuel. After a periond of cranking on it I can finally get fuel to come out of the bleeder on the top of the filter. Is it likely that the fuel is draining back down the line to the tank over the period of sitting, and if so is this normal?
Beersy50
Old Jan 20, 2008 | 08:48 PM
Franklin2's Avatar
Franklin2
It is likely the fuel is draining back. This is not normal, it means you have a leak letting air into the fuel system somewhere.
Old Jan 21, 2008 | 05:15 PM
turboman24's Avatar
turboman24
I had a hard starting problem with my truck once. It turned out to be leaking injectors. The truck would sit overnight and when i went to start it the next morning it would start after cranking some and then it would run for about 5 sec. and turn off. So it could be
1) Leaking Injectors
2) Pin hole in fuel line
There are other things that it could be but i think those would be the major two. I am sure others will chime in and give you some better advice as to what it could be, just sharing some of my past experiences.
Adam
Old Jan 21, 2008 | 06:07 PM
bigredtruckmi's Avatar
bigredtruckmi
Veteran: Navy
Look between the injectors at the fuel return lines. If painted "gray" --replace --they are original and are leaking air into the system causing the hard start problem. Also replace all seals for the caps.
Old Jan 21, 2008 | 07:38 PM
beersy50's Avatar
beersy50
Thanks for the info, sounds like I have some work to do, but now at least I know where to start, Thanks again.
Beersy50
