Bad brake(s)
Old Jan 20, 2008 | 07:32 PM
squaredancer's Avatar
squaredancer
Bad brake(s)
Long story short, discovered that the right front rotor is badly galled on the inside. I'll be taking it to my trusted wrench turner on Monday. The questions are :
1. If the rotor can be salvaged, should I do that or opt for a new rotor ?
2. If I opt for a new rotor should I replace the left front one at the same time ?
3. Keeping in mind that I pull a 11,000 lb 5th wheel up and down 6% grades that are 5 and/or 6 miles long, and another grade that's 7% for 3 miles, what would you recommend for brake pads ?
thanks for your advice.
Old Jan 20, 2008 | 08:51 PM
F350-6's Avatar
F350-6
I know most brake shops will recommend you replace both sides if you change one, but the whole purpose of all those brake parts is to adjust to the rotor/pad width as things wear down.
If your worried about your brakes in the mountains pulling a trailer maybe check into an exhaust brake.
Old Jan 20, 2008 | 09:03 PM
fixnair's Avatar
fixnair
I would replace both given your situation. I know going up and down the grapevine and Tejon pass can eat brakes. I weigh at 13K and travel the grapevine weekly. The rotors are not that expensive anyway.
Old Jan 20, 2008 | 09:58 PM
white Buffalo's Avatar
white Buffalo
I just bought the Powerslot cryoe'd rotors & hawk LTS brake pads from pure diesel power.com
Have not had a chance to even brake them in so I can not give you any personal experience, but many folks on this site recommended them.
I would replace both, only because I don't want to mess around with brakes, lost my trailer brakes once on the 5th wheel and that was enough to scare me.
http://www.puredieselpower.com/catalog/ford-products-brake-upgrades-c-30_102.html?osCsid=pddkd8elal2maemtevnp3rv1p5
Old Jan 20, 2008 | 10:30 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
I would look into the Hawk Superduty pads if youre mostly towing with it, and LTS pads for daily use.
Old Jan 20, 2008 | 10:38 PM
white Buffalo
When I talked with Garett he said the Heavy Duty pads were only if you towed 99% of the time, otherwise the LTS where the way to go.....
Old Jan 20, 2008 | 10:41 PM
PowerstrokeJunkie
Isn't that what i said?
Old Jan 20, 2008 | 10:42 PM
white Buffalo
After I read it again - yep, you did! I need to cut back on the booze.....
Drunk Buffalo
Old Jan 20, 2008 | 10:44 PM
ford390gashog's Avatar
ford390gashog
I would replace both and make sure the right caliper is not sticking. The rotors should not be turned. The min thickness does not allow it. New rotors are only 52.00 a piece.
Old Jan 20, 2008 | 10:50 PM
PowerstrokeJunkie
Drunk Buffalo
