Battery Light
Old Jan 20, 2008 | 06:30 PM
PAVEMENTMAN's Avatar
PAVEMENTMAN
Battery Light
I Noticed When I Start My Psd The Battery Light Stays On. It Shows Putting Out 14.4 Volts. It Sometimes Goes Out Then Comes Back On. Any Idea's.
Old Jan 20, 2008 | 06:36 PM
MADVAN's Avatar
MADVAN
Start with checking the connectors at the alt.
They tend to burn back.
Bill
Old Jan 20, 2008 | 06:42 PM
c00nhunterjoe's Avatar
c00nhunterjoe
mainly the 3 wire connector on top, they also spread terminals if somebody leaned on it while workin under the hood
Old Jan 20, 2008 | 06:45 PM
PAVEMENTMAN
I Jiggled Those But Still Nothing.
Old Jan 21, 2008 | 08:34 AM
Brians97F250Crew's Avatar
Brians97F250Crew
sounds like the rectifier bridge is going out to me. When they totally go out in the morning you can pop the hood before you start the truck. Everything else will be cold but the alternator will be warm. It allows current to flow back into the field coils makes like a heater coil. If the light goes out with RPM's added but comes back on at idle then it's time for an alternator or rebuild that one.
Old Jan 21, 2008 | 09:09 AM
PAVEMENTMAN
Its Showing 14.5 Volts While Running. I Noticed When It First Started Comming On I Was On The Highway And It Came On When The Rpm's Were Up And It Flickered And Went Out. Now It Just Comes On Occationaly.
Old Jan 21, 2008 | 09:56 AM
MagKarl's Avatar
MagKarl
My battery light comes on when the glow plugs are running, but goes out when it starts. Is that normal or do I have a problem too?
