Sponsored by: Auxito
5.4 porblems
Old Jan 20, 2008 | 12:30 PM
toolman9731's Avatar
toolman9731
5.4 porblems
i have this enoying problem when ever i give it a lot of gas the motor does absoutly nothing. the engine has 107,800 miles on it which people have told me thats nothing.
Old Jan 20, 2008 | 12:33 PM
superdutymj's Avatar
superdutymj
What year and engine is it? Explain the symptoms better too please.
Old Jan 20, 2008 | 12:39 PM
toolman9731
its a 99 5.4l triton
i wanted to show of at the light so a floored it and the motor parrley climbed in rpms
what could be the problem?
Old Jan 20, 2008 | 12:46 PM
superdutymj
Possibly clogged exhaust. How many miles do ya got?
Old Jan 20, 2008 | 12:53 PM
toolman9731
107,760 the exhaust has been replaced from the cat back
but when i just give it a little gas it really takes off
one of my friends says it has something to do with knocking noise coming from the back of the head
Old Jan 20, 2008 | 01:01 PM
superdutymj
doubtful. what kind of knocking noise is it? these aren't the quietest running motors to begin with. you might have a throttle position sensor acting up.
Old Jan 20, 2008 | 01:04 PM
toolman9731
i was told the knocking noise is from no oil at start up and it goes away when the motor warms up
i hope its not the throttle position sensor cause i am used to work on older trucks were you can see everything. i wouldn't no were to begin on the motor
Old Jan 20, 2008 | 01:07 PM
superdutymj
the throttle position sensor is i believe up on the throttle body. the knocking is probably piston slap that goes away when the engine heats up and the piston/rings expand.
Old Jan 20, 2008 | 01:08 PM
antony25's Avatar
antony25
Have seen a few air filter cones come off and get sucked up against the front of the mass air.
Old Jan 20, 2008 | 01:10 PM
superdutymj
Wow i've never seen that! Must have been on a FRAM filter. Pieces of junk...
Old Jan 20, 2008 | 01:14 PM
toolman9731
well that if that happened the mass air sensor is junk cause i am hace that tornado on it
Old Jan 20, 2008 | 01:24 PM
superdutymj
the tornado won't cause anything, especially power and fuel mileage increases ! he's saying the cone comes off the air filter and blocks your inlet to the sensor off. That cap isn't small enough to get into the maf sensor to cause any damage to the element. If you have the tornado, it probably didn't even get that far.
Old Jan 20, 2008 | 01:29 PM
toolman9731
i well check that but it is cold here in MI
so i really don't fell like taking it apart
if i keep driving it if that cone has come off will it do any damge
Old Jan 20, 2008 | 01:53 PM
superdutymj
i don't know that its the cone, as i haven't personally seen it happen, but you could use a scanner with freeze frame data to see if the tps is reading correctly. When you stepped on the gas hard, did it feel like it kind of stumbled and then took off?
Old Jan 20, 2008 | 01:55 PM
toolman9731
no it just started moving really slow
