Sponsored by: Auxito
5.4 porblems
Old Jan 20, 2008 | 03:20 PM
alberta46's Avatar
alberta46
Transmission slipping?
Old Jan 20, 2008 | 04:38 PM
toolman9731's Avatar
toolman9731
nope just had the trans rebuilt
and i have a trans temp gage and it doesn't leave 180
i think i might have a fuel problem
Old Jan 21, 2008 | 06:18 PM
Tsuga's Avatar
Tsuga
Originally Posted by antony25
Have seen a few air filter cones come off and get sucked up against the front of the mass air.
I don't mean to hijack, but what happens when this occur?
Old Jan 21, 2008 | 09:57 PM
LastSplash's Avatar
LastSplash
Have you replaced the fuel filter?
Old Jan 21, 2008 | 10:37 PM
superdutymj's Avatar
superdutymj
I'd replace the fuel filter and maybe run seafoam through a tank of gas.
Old Jan 23, 2008 | 10:28 AM
toolman9731
yeah i replaced it and it was not fun getting the old one off
what is seafoam
Old Jan 23, 2008 | 11:12 AM
KingRanchMan02's Avatar
KingRanchMan02
Seafoam
Old Jan 23, 2008 | 09:18 PM
toolman9731
okay i still don't know what seafoam is but what well it do
and today when i was picking my gf up from school on the way home the truck just came to life it was a bat out of hell
Old Jan 23, 2008 | 09:42 PM
ldfry001's Avatar
ldfry001
Have you replaced any of the coil packs? i have an 01 f150 with 100000 miles on it. i had some problems out of it at 80000 miles, so i replaced the coil packs and the problem was solved. also with that engine knock be careful, mine started doing that and then the heads locked up and i spun the cams and broke the valves. my friend who did the work owns a machine shop and said that it is common for the oil ports that deliver oil to the heads get plugged up and cause lack of lubrication on the top causing the heads to lock up.
Old Jan 24, 2008 | 10:16 AM
toolman9731
well i had the vavle covers off to figuer out what block it was and all the oil gallires were fine
i plan on butting some preformance heads
Old Jan 24, 2008 | 10:33 AM
KingRanchMan02
If you put your mouse pointer over the word seafoam in my previous post, it contains a hyperlink that takes you to the website for seafoam. You can also do a forum search for seafoam that will give you other information from people that have used it. Good luck!
Old Jan 24, 2008 | 12:43 PM
toolman9731
okay
the stuff looks like its not worth it to me and my firnd used it and it did nothing but carbon up the exaust so i will stick with slick 50 and zemax
