89 cat
Old Jan 20, 2008 | 11:48 AM
njtinman2's Avatar
njtinman2
89 cat
ive got an 89 f150 and the rear cat has a crack in it any info on changing it
Old Jan 20, 2008 | 12:06 PM
95F350XL's Avatar
95F350XL
I believe that the cat and the y pipe is 1 unit. You might be able to cut it out and put a high flow universal in.
Old Jan 20, 2008 | 12:21 PM
9299Fords's Avatar
9299Fords
The front cat is the two into one at the "Y". I was replacing the muffler on my 92 a few weeks ago and it seems the rear cat can be cut out and replaced without much problem. My rear cat was plugged up after the vehicle sitting for a couple years. I didn't have anything to replace it with at the time, so I hollowed it out with a hammer and bar. I think I'll go back under there and see if I can replace the front cat with a Y pipe and either go with a hi flow for the back or no cat. No emissions check here.
You could probably drop the back cat and replace it with pipe. You'd still have the front. Use clamps and yo0u could go back with a cat for inspection time.
Sorry for rambling.
Old Jan 20, 2008 | 03:00 PM
njtinman2's Avatar
njtinman2
live in nj need the cat dont know how good front one is
Old Jan 20, 2008 | 03:05 PM
95F350XL's Avatar
95F350XL
Im in NJ also, I just keep my old cat for when I go to DMV. I run no cat for 2 years, then on the day I put it on. Bassani is the only 1 that I have found that makes a Y pipe for our trucks. Its only for the Bronco/F150, 5.0 or 5.8. But im sure it could fit a F250/F350 with a little mod. As the factory F350 is a true dual Y pipe vs the 2 into 1 Y pipe on the others. If there is some pipe before the bad cat, just cut it off and replace with aftermarket peice.
Old Jan 20, 2008 | 04:02 PM
87white250's Avatar
87white250
take em both out ha you dont need em.... thats what I did but then again... im in TN
Old Jan 20, 2008 | 09:51 PM
9299Fords's Avatar
9299Fords
What is the In/Out size on the Bassani "Y" pipe?
'92 F150 5.8
Old Jan 20, 2008 | 10:21 PM
95F350XL's Avatar
95F350XL
The y pipe is 2.25, and the outlet is 3" I was trying to find a 2.5 but they dont have one. So i made mine when I did long tubes.
Old Jan 20, 2008 | 10:53 PM
9299Fords's Avatar
9299Fords
Thanks. I was hoping for 2.5 out. I don't know if 3" is overkill. That's a lot more pipe than the 2.25 stock.
Old Jan 20, 2008 | 11:03 PM
95F350XL's Avatar
95F350XL
3" is fine for stock engines. My stock cat is 3" on my 351.
