Help dead 01 7.3
Old Jan 20, 2008 | 09:43 AM
stanglvr's Avatar
stanglvr
Help dead 01 7.3
Hi Guys,
I am new to this site but I have had 7.3s for a long time I currently have 99,00,01 psds The 01 is giving me problems ,Here is what happened and whats been done. Just replaced #2 injector and cps running great washed motor still run fine parked overnight and would not start next day. I found no wait to start light checked and found blown fuse replaced fuse still no start. I have no tach or smoke ,Changed cps again still no tach and no smoke no run!!!! It has no codes in the computer, the hpop resv. is full hpop pressure is @2100 psi turning over.the motor has high miles on it it but it has to be something electrical ?????What else do I need to check??? I can rob parts off on of my others if need to.Please help!!!!
Thanks Lee
Old Jan 20, 2008 | 09:49 AM
gunnertom's Avatar
gunnertom
Was the blown fuse #30
Old Jan 20, 2008 | 09:55 AM
stanglvr's Avatar
stanglvr
Yes I beleive it was
Old Jan 20, 2008 | 09:57 AM
gunnertom's Avatar
gunnertom
Un plug the fuel boil heater an but in a new fuse.
Old Jan 20, 2008 | 09:59 AM
Orezona's Avatar
Orezona
Damn, second #30 fuse problem today!
stanglvr's Avatar
stanglvr
Already replaced fuse an wait to start is working again but still no tach no smoke no run
Old Jan 20, 2008 | 10:03 AM
gunnertom's Avatar
gunnertom
check the fuse again, when you tried to start it you probably blown it again.Unhook yhe fuel bowl heater first.
Old Jan 20, 2008 | 10:04 AM
stanglvr's Avatar
stanglvr
Nope not blown again
Old Jan 20, 2008 | 10:07 AM
gunnertom's Avatar
gunnertom
Check to see if you got the cps connector wet.unplug an blow it out.
Old Jan 20, 2008 | 10:12 AM
stanglvr's Avatar
stanglvr
Seems ok what elese can caues no tach no smoke condition
Old Jan 20, 2008 | 10:14 AM
Orezona's Avatar
Orezona
Do you still have the old CPS? If so, I'd try slapping it back in just to rule out the new one being a POS.
Edit: And still unplug the bowl heater and replace the fuse that looks good anyway.
Old Jan 20, 2008 | 10:17 AM
stanglvr's Avatar
stanglvr
No the one that was on the truck was the new grey one only a few weeks old I had another old black on not for sure it was good I might take the one out of the 99 cause I know its good .
Old Jan 20, 2008 | 07:01 PM
stanglvr's Avatar
stanglvr
update changed cps with one I know is good still not running. Truck is inside shop 75 degrees even plugged it in checked all fuses relays etc fuel pressure is @110 psi at pump output under truck.I even undone the bowl heater. The truck acts like it might want to hit a lick every now and then but nothing major still not hardly any smoke like when trying to start in cold with faulty gp's> If you hit it with either it will fire for a second or as long as you shoot the either to it while you still crank the starter.I have cleaned the harness connectors at the valve covers and other random connectors
Any more ideas ????? Any help is appreciated!!!!
Old Jan 20, 2008 | 07:16 PM
F350-6's Avatar
F350-6
First don't use the ehter. If you have to use something try wd-40. Are you saying the truck starts with the ether, but then dies as soon as you quit spraying? Is your fuel filter clean? Why did you replace the #2 injector? If you washed the engine before the no start, have you checked the IDM to see if it got wet?
Old Jan 20, 2008 | 07:26 PM
stanglvr's Avatar
stanglvr
Yes runs as long as you spray quit spraying quits running,# 2 injector was bad had a skip in it ,fuel filter is only a few weeks old .IDM seems to be dry ,It acts like it is not getting any fuel still????
