warm up question
Old Jan 19, 2008 | 09:03 PM
9973's Avatar
9973
warm up question
When I start my 99 7.3 in the cold, it starts fine. then when the engine revs up for the warm up cycle it starts to kinda rev then hesitate. it kinda seems like the wastegate is opening or something but it is a consistent rev then slow down. Even the first few miles I drive it does this. today I looked at the turbo while it was doing this. I could just barely see under the exhaust side (passenger) something moving up and down as it was doing this. I dont know what it is. I cant seem to find a good picture to show me. can anybody help
Old Jan 19, 2008 | 09:29 PM
9973's Avatar
9973
could it be a blow off valve. It seems like it is building pressure then dumping.
Old Jan 19, 2008 | 09:35 PM
Tenn01PSD350's Avatar
Tenn01PSD350
Your EBV seems to have issues. Is your tube clogged? Is this what you saw moving?
Old Jan 19, 2008 | 09:39 PM
9973's Avatar
9973
yeah I think so . It was going up and down as the engine reved then slowed. Any Idea how to fix
Old Jan 19, 2008 | 09:40 PM
9973's Avatar
9973
what is EBV and what tube
Old Jan 19, 2008 | 09:42 PM
HKusp's Avatar
HKusp
It shouldn't have a blow off valve. The powerstrokes don't have one.
Does it sound like what is referred to as the "romp romp romps"? Meaning it has a quick rhythm to it.
Old Jan 19, 2008 | 09:45 PM
9973's Avatar
9973
no its not quick but it does have a rhythm to it
Old Jan 20, 2008 | 09:48 PM
JIM ROLAND's Avatar
JIM ROLAND
Go here: http://guzzle.rbmicro.com/ebps.html
This will help you a lot with checking & cleaning the tube and sensor. Be sure to check the fitting on the exhaust manifold as it says, and be careful when probing into the sensor itself. I done mine by these instructions for the first time and it wasn't hard at all. The hardest part was clearing the tube with a weedeater string and not using it on a drill. The brake cleaner works like a champ to loosen it all up. GOOD LUCK! Hope this helps!
BE SURE TO POST BACK AND LET US ALL KNOW HOW IT WENT, AND IF IT FIXED THE PROBLEM! THANKS!
Old Jan 20, 2008 | 10:00 PM
tucker1999's Avatar
tucker1999
How often should a person check and or clean the tube and sensor? My rig has about 175k on it and I have never done this.
Old Jan 21, 2008 | 07:04 AM
JIM ROLAND's Avatar
JIM ROLAND
I guess every truck is different depending on the use, driving habits, tunes etc. Mine is completely stock and had 69k on it when I bought it. I cleaned it at approx. 141k and it was almost, if not completely, stopped up. I don't know if the previous owner ever cleaned it or not, but I doubt it. It's probably a good time to check yours, then you'll know for sure. I've seen some guys on here that say they do it as routine maintenance at 15k intervals or so. Maybe someone else will chime in with different, or better, advice. Good luck!
Old Jan 21, 2008 | 07:43 AM
tucker1999's Avatar
tucker1999
Thanks for the info. I probably should check it anyways, right now is a good time anyways. Truck is standing on three legs, (transmission is in the process of getting rebuilt)
Old Jan 21, 2008 | 07:59 AM
wfmcbride's Avatar
wfmcbride
135 K on the clock, haven't done mine yet, if it's below 30* and I forgot to plug in the heater I'll get a couple romps sometimes.
Old Jan 21, 2008 | 08:19 AM
jhand124's Avatar
jhand124
I went to clean my EVBP tube and it was totally clogged and rusted though, I had 200K on the truck and it had never been cleaned. I replaced the sensor too.
Old Jan 21, 2008 | 08:55 PM
9973's Avatar
9973
yeah i cleaned mine. it didnt solve the problem with it warming up the way it does so I just tried and unplugged the sensor and that fixed the problem. so i ordered a new sensor. thanks for the help
6brau
Jun 2, 2013 11:48 AM
IDIDieselJohn
Sep 26, 2010 06:50 PM
Kmansinger
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Sep 25, 2008 09:58 PM
Mikes67F250
Modular V8 (4.6L, 5.4L)
May 20, 2006 08:33 AM
