Offroad & 4x4
Why do we complain and argue?
Old Jan 18, 2008 | 06:53 PM
crazyredneckanyhow's Avatar
crazyredneckanyhow
Ok so its time to have an adult discussion. Please try to be serious and give a good argument but be NICE!!!! Ok so here we go. You know lately there have been alot of guys wanting info on 4wd conversions. Alot of them question chopping two frames and adding the 4wd front frame to their existing frame. We ( and i include me here) have warned against it and even got into a couple arguments about it. But here i ask you : Why do we advise against it? My main reason is because i dont know anything about John Doe's welding experience so i just say no. But the reason i raise this is because of an episode of Exteme 4x4 on spike. They made a truggy and built a box tubing frame. They didnt bend the tubing where it needed it they just cut pieces at an angle and welded them up and used gussets. So with seeing this i was wondering why couldnt i cut a frame and stretch and/or shorten it and weld it back together? Just fish plate it and box it then it would be just as strong. I have confidence in my welding and confidence in the certified welders i have for friends. So i asked why do you advise against this?
Old Jan 18, 2008 | 07:30 PM
Kylet8020's Avatar
Kylet8020
umm weildin weakins the frame ???? for a tow truck i know it against the law to weild the tow bed to the frame
Old Jan 18, 2008 | 07:34 PM
crazyredneckanyhow
Its all about how you go about welding. As far as welding a bed to a frame thats not a good idea no matter what kind of bed. It takes away the flexibility of the frame.
Old Jan 18, 2008 | 07:41 PM
Kylet8020's Avatar
Kylet8020
not the flex we are worried about you dont want me dragging your nice clean oil pan always been told to much weildin weakins the frame but i dont know to much about weildin but just ask me to cut your frame up with a torch
Old Jan 18, 2008 | 07:45 PM
crazyredneckanyhow
Its all in how you do things. Cutting a frame with torches is always a bad idea unless you want to junk it. 73-79 4wd trucks had a crossmember and boxed rails all welded from the factory. A frame is so large that heat distribution is not a real issue. Ive been welding for years and ive alread spliced a 77 Riveria front frame section to a 53 buick. Worked great and its pushin 500 hp and havent broken a weld yet.
Old Jan 18, 2008 | 07:51 PM
Kylet8020's Avatar
Kylet8020
well all i know is what i was told it not being true i would go with dont do it becouse john doe dont know what the hell he is doin
DesertStorm's Avatar
DesertStorm
Welding does not weaking the frame. Some idiot a few years back had the bright idea to tell everyone that frames were made of cold rolled steel or some crap like that. It is fine to weld on the frame. If you are piecing together a frame you need to know how to support it with additional steel then weld it. You need a proper welder and know how to use it. Teaching yourself behind the barn on grandpas tractor bucket does not count. Get a state certified welder to weld it. If i have to weld anything on my truck that could even remotely endanger my life I let my friend who is certified weld it. Safety first. A truck frame is 1/8 to 3/16" mild low carbon steel. Just forged into a long piece of c-channel. No different than welding any other piece of metal.
Old Jan 18, 2008 | 07:55 PM
dmanlyr's Avatar
dmanlyr
Depending on the material that the frame is made of, welding is either a go or a no go.
Easy way is to look at how the factory fab'd the oem frame, if the front cross member is welded, and the front of the frame is boxed (welded again) then it is made of the lower strength / tensil steel which can be welded.
If however, it is like what is curently used on some newer trucks (well subjective, made in the last 20 years or so), up to and including semi's and the frame is all rivited, then it is NOT acceptable to weld on the frame. These are of a special high strength steel, high tensil strength, but very prone to cracking when welded. The reason for using this material is to reduce the tare weight to maximize the load capacity.
I am sure that most have seen the semi's with the "DO NOT WELD" stickers on the rear of the frame. They are there for a reason.
David
Old Jan 18, 2008 | 07:56 PM
crazyredneckanyhow
Exactly. If you know what you are doing its not a bad idea. And you were right bout learning to weld on pappys tractor.
Old Jan 18, 2008 | 08:00 PM
dmanlyr's Avatar
dmanlyr
Yopu made some good points, excellent post, I agree with 90% but, only some truck frames are of this material. Not all.
Some can be welded, some cannot, regardless of welding certification.
David
Old Jan 18, 2008 | 08:04 PM
crazyredneckanyhow
Dmanlyr, thanks for the heads uon the new stuff. I didnt know that. Im pretty much into the 73-79 era trucks.
Old Jan 18, 2008 | 08:06 PM
DesertStorm
David
I let the weldee decide. He is also a tube chassis builder and mud track racer. He hasnt let me down. Which is a good thing.
Old Jan 18, 2008 | 08:13 PM
Kylet8020's Avatar
Kylet8020
well then i would say we say DONT becouse all of the john does that dont know some of what seem to basic knowledge
Old Jan 18, 2008 | 08:19 PM
crazyredneckanyhow
Im waiting on the opinions of some of the others to see whats what. im not askin a yes or no question but more of a why.
Old Jan 18, 2008 | 08:34 PM
DesertStorm
this coming from someone who dosent know how to spell WELDING, not weilding.
