460 dipstick/oil pump question
Old May 2, 2002 | 11:56 PM
fordmando's Avatar
fordmando
I'm sticking a 460/C6 into my 70 Ford F-100. It had a 400/C6 already installed by the PO. I have factory engine mounts from a 73-79 truck, they bolted right in. I also got a front sump, truck pan (it is just a little deeper than a car pan, and has the oil drain on the side to clear the crossmember.
The engine is a 77 460 out of a E350. It had a rear sump pan, but was damaged and needed to be replaced anyway. It had a dipstick tube on the pan, the new pan does not have provisions for a dipstick tube. So, what to do about the dipstick tube?
Also, I'm haveing some trouble locating the right pickup tube and oil pump for this application, anyone have an idea on what oil pump and pickup I need?
Thanks
fordmando
70 F-100
78 F-150 4x4 400 NP435
George Selby
Old May 3, 2002 | 01:34 AM
merc460's Avatar
merc460
If your front timing cover does not have a spot for the dipstick tube or you cannot put a tube in to your timing chain cover you will need to change the timing cover to the front sump style with a spot for the dip stick. As for the oil pump pick up I bought a melling hivolume oil pump and it came with a bolt on front sump pan pick up tube Eric
Old May 3, 2002 | 01:57 AM
mike460's Avatar
mike460
hasteranger
26
Sep 15, 2012 07:03 AM
mattscot007
Dec 9, 2005 02:22 PM
fordmando
Bronco II
Oct 28, 2002 07:19 PM
fordmando
Apr 24, 2002 11:09 PM
