pukeing oil
Old Jan 18, 2008 | 06:34 AM
keepnthepeace's Avatar
keepnthepeace
pukeing oil
I ran up on a truck with a lot of miles and lots of idle hours on it (275,000miles). There is a chance i will have an opprotunity to buy the truck fairly cheep. Here is the bad news the motor pukes oil out into the air filter. I was wondering what can cause the motor to puke oil like that? Stuck piston ring, bad o ring on an injector, cracked piston? I am just not experienced with this kind of problem. Any and all help is appreciated.
Old Jan 18, 2008 | 07:53 AM
clux's Avatar
clux
Most likely blow by, especially if the engine has a lot of idle time on it like you suggest.
Old Jan 18, 2008 | 11:59 AM
keepnthepeace
what exactly causes the blowby. Bad rings, valve seals, etc.?
Old Jan 18, 2008 | 12:13 PM
clux's Avatar
clux
Yes, worn out rings.
Old Jan 18, 2008 | 12:27 PM
keepnthepeace
what kind of repair bill are we talking to fix this engine? It runs fine, good and strong.
Old Jan 18, 2008 | 12:47 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
Blow by is a nomal thing, and its impossible to just "puke" oil. The way the oil gets there is the design from the factory- an inlet connected to the left valve cover pulls the crankcase under vacuum when the turbo is spinning, due to the intake vacuum. Over time this oil vapor builds up and puddles oil in the engine's intake which looks like it shouldnt be there.
