Fuel Pump Question
Old Jan 18, 2008 | 06:24 AM
xjoedirt55x's Avatar
xjoedirt55x
Post Fuel Pump Question
Hi all, I have never worked on an explorer, but my buddies just will not start, it is cracking just fine, and getting spark, so I am guessing the fuel pump. It is not the inerta switch as that was already checked. My question is does anybody know a way to check and see if the fuel pump is working or not on these without hooking up a fuel pressure test or dropping the tank right away? Should the fuel pump be audible? Any help is greatly appreciated.
Old Jan 18, 2008 | 10:40 AM
mrshorty's Avatar
mrshorty
What year Explorer?
Fuel pump should be audible. Get a stethoscope and poke at the tank, that might help.
You could hook up an ammeter in line with the fuel pump and see if it is drawing current when it should. You could also hook up an ohmmeter and see if the fuel pump has continuity. A voltmeter at strategic locations in the fuel pump circuit can tell you where/when voltage is being applied.
If the fuel pump circuit checks out electrically, the only sure test of the fuel pump's performance (and the rest of the fuel delivery system) is to hook up a fuel pressure gauge.
Old Jan 18, 2008 | 01:06 PM
aquanaut20's Avatar
aquanaut20
Check the FP relay in the main power box under the hood...
Old Jan 19, 2008 | 08:02 AM
marragtop's Avatar
marragtop
Yes, check the relay in the PDB. You switch it with one of the other ones that are not part of the starting sequence. Also, make sure that the wire is firmly connected on the bottom of the inertia switch. If the wire comes off, it won't pop the switch, but it is needed to feed juice to the FP.
WhiteBeast-05-powers
22
Feb 1, 2022 10:14 PM
sitdog84
May 28, 2014 01:44 PM
DAI532
27
Sep 24, 2009 08:34 PM
Ed_B1
Nov 21, 2003 12:50 PM
jls73
Jul 5, 2003 11:12 PM
