Modular V10 (6.8l)
Changed Plugs.... Now chugging
Old Jan 17, 2008 | 09:24 PM
jeepthing's Avatar
jeepthing
Changed the plugs and boots on my 01 excursion yesterday. Truck has 80k on it and had a small mis-fire at around 1700 rpm, so I figured i'd do plugs and coil boots. Was alot easier than i thought it would be..... By the way, dealer said torque specs for plugs was 11 ft lbs. but i torqued them to 20....
Now truck Has no mis-fire at 1700, but is mildling "chugging" from a takeoff. Almost feels like an injector. Any ideas before i Tear it apart again?
Old Jan 17, 2008 | 11:25 PM
3000 FPS's Avatar
3000 FPS
Does it show a check engine light on the dash.
Old Jan 17, 2008 | 11:34 PM
biz4two's Avatar
biz4two
Arrow
Did you disconnect the negative battery cable while doing the spark plug change? This resets the PCM...
biz
Old Jan 18, 2008 | 07:28 AM
Big Orn's Avatar
Big Orn
Maybe your misfire wasn't a plug after all, but a coil (COP) or boot?
Old Jan 18, 2008 | 10:50 AM
big blu's Avatar
big blu
Just a thought, but did you make sure the plug gap was correct?
Old Jan 18, 2008 | 10:54 AM
andrewzx92000's Avatar
andrewzx92000
It might be a coil or a bad boot. Wait until it becomes a real full blown miss on that cylinder and then go around unplugging each coil until the one you unplug does not change the way it is running, that will be the one with the bad coil or boot. New coil at O'Reilly for $50 with lifetime warranty with boot. Boots there are cheap too, good quality
Andrew.
Old Jan 19, 2008 | 01:35 PM
jeepthing's Avatar
jeepthing
OK, chugging got worse and now has a very noticable mis-fire at most low rpm speeds. So i changed the plugs, Again, thinking maybe a fouled plug. New plugs but the same result.........I guess now i'll do 10 new coils. Any Ideas would be apreciated
Thanks
__________________
Old Jan 19, 2008 | 02:09 PM
2000silverbullet's Avatar
2000silverbullet
Go buy one coil and switch them out with the new one until you find where it runs correctly. 10 new coils is big $$$.
Old Jan 19, 2008 | 02:11 PM
Charlie Bravo's Avatar
Charlie Bravo
I don't think I would go with ten new coils just yet. Get someone to download the info stored in the vehicle computer. That will tell you which if any are bad.
Best, CB
Old Jan 19, 2008 | 06:05 PM
3000 FPS's Avatar
3000 FPS
Thanks
__________________
I know you know something about computers because you are here on this forum and I know that you are mechanical because you changed your own plugs. On ebay you can find can bus readers for less than 100 bucks and they are really simple to use. The plug is right there under the dash on the drives side and is really easy to get to. The can bus reader is just another tool just like a torque wrench or any other tool you would buy. The nice thing is the can bus reader will actually tell you which cylinder is doing the missing from the code that you retrieve. Then you only have to figure out what is wrong with just that cylinder and not all 10 of them.
Old Jan 22, 2008 | 10:24 PM
jeepthing's Avatar
jeepthing
$125 bucks later and she running like a champ. Verdict: Bad COP cly# 1. There was NO stored memory of mis-fire, so cheap autozone scanner, nor very expensive snap-on scanner told me which coil was bad. So a $75 diagnostics and a $50 cop got me back on the road
Old Jan 22, 2008 | 10:47 PM
3000 FPS's Avatar
3000 FPS
Thanks for the feedback but I am surprised it never stored a code. I guess the miss was not bad enough for the crankshaft position sensor to pick it up. That is good to know.
Old Jan 23, 2008 | 09:49 AM
andrewzx92000
Like I said, you can go around with the engine running and unplug each coil until it runs just the same with the coil disconnected and missing, this is the one that is acting up. No need for computer plug ins. As long as it is missing pretty consistently you can do this in minutes and go buy the coil. I have gone through two of them.
The Scan gauge I bought recently does tell me which cylinder has a miss on it and a whole bunch of other cool information for 159 bucks.
Andrew
NikkiNM
Jan 27, 2012 07:25 AM
ApachePete
2004 - 2008 F150
Nov 7, 2011 10:59 AM
borg_99
Dec 8, 2010 04:45 PM
rodneytxps
Modular V10 (6.8l)
22
Mar 8, 2010 06:54 AM
jeepthing
Jan 23, 2008 06:21 AM
