Replacing lower BJ's Sat...Question?
Old Jan 17, 2008 | 06:07 PM
makomaker's Avatar
makomaker
Replacing upper and lower BJ's on '02 F350 4WD Sat morning..
While I'm in 'there' any prevent maintenance I can knock out?
Thanks, J
Old Jan 17, 2008 | 06:37 PM
DISLFVR's Avatar
DISLFVR
Locomotive breath
Brake caliper slide pins would be one.
Old Jan 17, 2008 | 06:55 PM
tbirdage's Avatar
tbirdage
You can pretty much expect to change your outer axleshaft seals, the ones that go thru the spindle. They're about $45 a pop from the stealer, and the dust seals for the end of the axle tube housing. (NAPA $13 each). Go ahead and get the yellow o-rings for your wheel bearings (dealer, $5 each), and grease the needle bearings inside the wheel bearings. If these look bad, NAPA also has these for $11 each
Old Jan 17, 2008 | 08:46 PM
totin_tools's Avatar
totin_tools
Get a installer kit and everyone of the forks you can from the parts store. I needed to make several trips to the store to get all the tools I needed. Good luck its a PITA.
