HEET in fuel?
QUOTE]
I was out ice fishing 3 weeks ago and it was around 34deg with the sun out. There was a sustainable wind of around 20mph. If wind does not affect liquid freezing why was the wind chill causing my ice holes to freeze over? Earlier in the morning when the wind was calm my holes wern't freezing over, only when the wind started.
Water is a surface just like your skin and can be affected by the wind chill. Of course fuel inside a tank isn't as effected.
I had an 89 c3500 with a 6.2 GM diesel (AND DONT GIVE ME ANY GUFF ABOUT IT EITHER, I have either heard it or said it.) It was a company truck.
It was susposed to be 20 deg the next morning it was January so they were pumping winter grade fuel. I was still using extra "Power Service" to prevent fuel jelling. I used the right amount and put it in each tank. the next morning I went and loaded my truck about 5 am (with engine ideling) and headed out on my route about 5:30 am drove about 8 miles with decreasing power finally my fuel filter clogged and I was sitting in a parking lot in a town of 200 with not even a gas station open. I always carried a spare fuel filter so I put it on and the damed thing wouldnt prime, jelley was all I could get.
I was pi$$ed I walked to a pay phone and called the wrecker.
long story short
I had mixed for 20 degrees wrecker driver told me always mix for 30 deg less then the temp was going to be.
from then on 1 gal gasolene to 20 gal of diesel PLUS power service.
jim
What kind of gauge did you use? I would like to install one of those in my 2005 V10.
Thanks ~Gage~
The only problem I had was with the 7' ethernet cable supplied with the blendmount kit. The 7' cable was too short to go from the scanguage mounted to the rear view mirror to under the dash the way I routed the cable. I bought a a 14' ethernet cable at staples and that solved the problem and I could route the cable so it is hidden. The scangauge uses a standard cat5 or cat 6 ethernet cable which is nice. Overall I'm happy with my scangauge.
I means the wind chill question. Oh boy! They never should have foisted this complex scientific theory on a public so "science knowledge" starved...and it gets better all the time.
Wild chill only effects items having a heat difference, generally, more heat than the surrounding (ambient, remember that term form 9th grade general science?) air or environment. Wind chill (the weather folks sometimes use the term "the 'feels like' temperature" for science dummies) is a way to explain the RATE of heat change (usually it's a LOSS). Once the item reaches the temperature of everything around it, it has no temperature difference and wind chill no longer applies, so whatever the real temp. is is what your water, hand or cup of coffee will be.
A side note:
I worked for a number of years as a route delivery driver, three years of which were as an owner-operator independent route distributor in the Rochester, NY area. One of my fellow distributors was having trouble with his truck one cold winter day. This guy was a lifetime Roch. area resident and had run a truck for several years (everyone ran gasoline engines then, diesels were just becoming available in smaller trucks).
I couldn't believe my ears when he had absolutely no idea what I was talking about when I asked him if he ever used dry-gas or some such product. He'd never heard of doing so. Consequently, he had a load of water in his fuel system.
He moved to Atlanta, Ga....he'll make out better there, I think.
Moving air over the surface of a body of liquid WILL cool off the liquid below ambient air temp.
With solid objects, you are correct.
However, in a liquid (or any mass no matter the form) the molecules are all moving (vibrating) at a certain rate - higher temperatures make it faster, lower make it slower. The actual temperature of the liquid is an AVERAGE. Not all molecules are vibrating at the same rate. Some are faster (hotter), some slower (colder).
Some of the molecules are vibrating so fast that they leave the liquid. This is evaporation.
As the evaporation continues, the more molecules leave the liquid, LOWERING THE AVERAGE TEMPERATURE.
Moving air over the surface of a liquid speeds up evaporation. So, the remaining liquid cools down even faster.
This also happens with substances that sublimate like dry-ice (carbon dioxide). They go right from solid to gas. And even when kept at the right freezing temperature, some of the molecules are still hotter than the rest and will escape. Leaving the remaining block of dry-ice even colder.
I can definitely see where a 34-degree day would result in an ice-hole freezing over on windy days...
The surface water temp would be around 34-36 deg. Once you get into a certain depth of water the temperature is actually warmer than the water towards the surface during the winter.
