85 gauges
Old Jan 16, 2008 | 11:37 PM
rogmale's Avatar
rogmale
85 gauges
Trying to figure out a friends ranger. Starts and runs but no gauges working other than amps. Anyone have any clues on it for me? Thanks
Old Jan 17, 2008 | 05:50 AM
Lead Head's Avatar
Lead Head
Do the radio and windshield wipers still work?
Old Jan 17, 2008 | 11:10 PM
rogmale's Avatar
rogmale
headlights and dash lights are good, but no on the wipers and radio. Problem started after ignition switch spun 360.
Old Jan 18, 2008 | 11:44 AM
jimdandy's Avatar
jimdandy
The gauges are not receiving power. You probably broke the wire when the switch spun. There is a voltage regulator on the back of the instrument cluster that feeds the fuel, temp, & oil pressure gauges. The wire to the regulator from the ignition switch is blk/ltgrn. There is also a wire of the same color going to the low fuel warning module. Both should have 12v with the igniton on. jd
Old Jan 18, 2008 | 02:15 PM
Lead Head's Avatar
Lead Head
On my 87 ranger, when we first pulled it out of the woods, we had lost the keys, and hack to hack the ignition cyclinder all apart, and hot wire it. After we nearly destroyed the steering colum we found the keys >.<
But anyways, if you take the cover off the column (should be held on with two screws, you should see the connector that goes into the ignition switch.
You will see two thick yellow wires, and directly below one of the yellow wires will be a black wire. This wire feeds the instrument cluter guages (not lights, jsut the guages), radio, and windshield wipers. Try splicing a connection from one of the yellow wires to the black one, and then try starting the car.
Old Jan 19, 2008 | 01:12 AM
rogmale's Avatar
rogmale
Those suggestions make sense, even if i do hate electrical. will check it. appreciate the knowledge base and help. Thanks
