battery cables
Old Jan 16, 2008 | 07:59 PM
roc0999's Avatar
roc0999
battery cables
where is the best place to get replacement positive and negative cables for a 2000 f 350 7.3 , I checked w/my local dealer and it was like 400. for 3 cables , I was like WOW. If I could get some help that would be great thanks, Ron
Old Jan 16, 2008 | 08:06 PM
PSNut's Avatar
PSNut
How about a local marine supply or electrical supply store. You might have to
get a little creative but it shouldn't be too difficult to figure out.
Old Jan 16, 2008 | 08:08 PM
roc0999's Avatar
roc0999
I would rather find the proper parts at a reasonable price than to make something work
bdrummonds's Avatar
bdrummonds
Go to your local INTERSTATE batteries wharehouse, the have the complete positive side for $80 (just replaced mine in nov.) you can have the neg sides made up there for about $20 -$25 each
Old Jan 16, 2008 | 08:17 PM
F350-6's Avatar
F350-6
Battery cables are nothing more than a certain type of wire (guage/strand). If you can get a better deal at a marine shop or electrical house then there's nothing wrong with that. You would just need to put ends on the cable you bought.
What's the reason you have to replace all your cables? If it is related to corrosion then maybe the upgraded ends put on a custom cable would be a better route. I'm not a big fan of the thin, cheap looking connectors they put on vehicles today.
By the way, Welcome to FTE.
Old Jan 17, 2008 | 12:07 PM
Smokin''s Avatar
Smokin'
Smokin
You can also buy cables online:
Negative:
http://trademotion.com/partlocator/i...layCatalogid=0
Positive:
Ray (rbaker) was kind enough to give me this info so I thought I would forward. I also have cables that are going down the crapshoot (worn out connectors) but haven't gotten around to purchasing new one's yet.
Old Jan 17, 2008 | 12:15 PM
mudmaker's Avatar
mudmaker
I get my cables made up at a local starter alternator shop. They are alway reasonable and the finished product looks like it was factory. Just call around to starter shops and battery suppliers.
Old Jan 17, 2008 | 01:19 PM
Rock Auto Justin's Avatar
Rock Auto Justin
Former Vendor
We've got the genuine Motorcraft parts in our catalog, here's a link. Just match up your OEM numbers to make sure you're getting the correct ones.
http://www.rockauto.com/catalog/x,ca...,parttype,2500
Thanks for looking!
Justin
Old Jan 17, 2008 | 03:00 PM
vettdvr's Avatar
vettdvr
Warning,, Today I had a slow start but it did start. After full warm up I checked the charging system that verified ok. So I decided to clean the battery cables. What a job. corroded in place. Had to use a grinder to get one of the bolts out to remove the cable (Ok,, No sparks of course due to hydrogen risk). Fan used etc.
After fighting to get all 4 cables off, cleaning drilling out the hole to 5/16 and replacing bolts with new bolts it started up normally. The cold start tomorrow will answer if it needs new batteries. So check your cables and clean the bolts to prevent the hassel I had today.
Old Jan 17, 2008 | 07:23 PM
mcjones44us's Avatar
mcjones44us
I had cables made out of 3/0 guage wire at my local interstate batteries shop. The bill for that was $112 for one positive and two negative cables. Fit perfect.
Old Jan 18, 2008 | 09:09 PM
roc0999's Avatar
roc0999
i went to my local interstate battery shop today and they replaced my terminals w/heavy duty ones and put eyelets on my cables and fixed my problem for under 60.00. That was awesome and I wanted to thank everyone for all your suggestion's , Thanks, Ron
ron young
New Member Introductions
Feb 12, 2014 12:40 PM
guitarpicr
Apr 11, 2009 07:05 PM
Snake1979
20
Mar 26, 2006 01:58 AM
rons
Jun 12, 2000 06:54 PM
