Sponsored by: Auxito
stuck spark plug
Old Jan 16, 2008 | 12:33 PM
dvs2586's Avatar
dvs2586
stuck spark plug
i have a 1997 ford expedition and one of the spark plugs is stuck and won't even budge out any advice??
Old Jan 16, 2008 | 12:42 PM
winsorcoke's Avatar
winsorcoke
Try warming the engine up. It might come out easier when it's hot.
Old Jan 16, 2008 | 01:15 PM
f-150 on 22's's Avatar
f-150 on 22's
Just spray some PB Blaster down around the plug and let it sit for an hour or so... Just don't break it whatever you do!!!!!!!!
Old Jan 16, 2008 | 01:38 PM
galaxie641's Avatar
galaxie641
When it comes out you will need to check the plug for aluminum flakes and look into the head to see if any of the threads were stripped.
Old Jan 17, 2008 | 09:32 PM
angus67's Avatar
angus67
pb is awesome!!!pb drinks wd40 for breakfast!!! I needed to rebiuld the front of my fairlane, and knew itdb a pain, so two days prior I spray every nut and bolt, and it came apart like it was put together yesterday. I only use wd for keeping drill bits cool.
Old Jan 17, 2008 | 09:52 PM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
We had to use an impact on one of the plugs on my buddies Toyota
Old Jan 17, 2008 | 10:08 PM
superdutymj's Avatar
superdutymj
spray some penetrating oil on it, and put your socket on the plug with an extension and tap the end of the extension a few times with a hammer, that ought to loosen it up.
Old Jan 17, 2008 | 11:35 PM
angus67's Avatar
angus67
idk, plugs are pretty fragile. make sure its your last resort before picking up the BFH.once the end is busted off, its hard to get a socket on straight enuf and turn the hex
Old Jan 18, 2008 | 12:06 AM
superdutymj
i've always been able to get mine loose that way. don't get carried away or anything, just a few light raps nice and square on the end of the extension to help that penetrating oil get in there better
Old Jan 18, 2008 | 06:10 AM
oldstylefseries's Avatar
oldstylefseries
The absolute BEST and I mean BEST penetrating oil that I've ever found is KROIL. We use it in the lab where I work. I've done many of these plugs and suggest this:
1) Blow out the plug hole before even touching the plug. This will get the
dirt out of the hole and keep it from falling in upon plug removal.
2) Spray some KROIL down in the hole and LET IT SIT for about an hour.
3) Go out and GENTLY turn the plug about 1/8 of a turn and add a LITTLE
more KROIL and LET IT SIT for another half hour or so. This will allow the
KROIL to get down into the spark plug threads.
4) Turn the plug out 1/4 turn, then in a little. Then out a little, then in a little
This should solve your problem and I hope this helps.
Old Jan 18, 2008 | 07:02 AM
f-150 on 22's
You two got some big kahunas!
Old Jan 18, 2008 | 07:30 AM
Spotty's Avatar
Spotty
Old Style said it perfectly, "slow and soak", turn it back in a hair, you'll have it screamin' for it's Mommee' in no time. I believe in doing it with a stone cold engine, what do you other guys think? I work on motorcycles a lot, if I have to pull a plug on a warm aluminum head, feels like I'm taking some threads out with it.
Jeff
Lucille1986
Apr 2, 2013 11:08 AM
Crf45or1991
Oct 6, 2011 08:14 AM
dvs2586
New Member Introductions
Jan 15, 2008 03:17 PM
vadphoenix
2004 - 2008 F150
May 5, 2007 12:18 PM
roc.r1
Jun 28, 2004 02:11 PM
