Heater Blower
Old Jan 15, 2008 | 11:58 PM
expuller's Avatar
expuller
Heater Blower
I was driving and shut off the truck to get gas after that the heater will not turn back on. I checked the fuses but was wondering if there is anything else. I would suspect this is more electrical. Please help me it is cold.
2006 150 4x4
Old Jan 16, 2008 | 12:01 AM
mattd17's Avatar
mattd17
there was just a post about this a couple weeks back.... i guess there is a resistor for the blower motor inside the passenger side door a-pillar. try a search for it, and you will get some better info.... i remember reading one about 1-2 weeks ago. it wasa cheap fix for the guy too.
Old Jan 17, 2008 | 08:40 PM
Medic911's Avatar
Medic911
The resistor controls only speeds 1, 2 and 3. You should still have high as it is not routed through the resistor. If you have no high speed..you have a different problem.
Old Jan 17, 2008 | 09:10 PM
morrowtruth's Avatar
morrowtruth
could try the primitive technique and tap the blower motor housing. you may have multiple fuse boxes(driver and pasenger side,under hood) or could be in head unit. sometimes taking ***** off and spraying electrical contact cleaner behind them helps. or if its vacume controlled a loss of manifold vacume can be a problem, but probably not for the blower motor.
Old Apr 21, 2013 | 10:23 AM
KJ52's Avatar
KJ52
my brothers 05 F-150 4x4 4.6l vin:W, blower motor lost positions 1,2,and 3. I replaced the BM resistor, positions 1,2,and 3 worked briefly before 1,2,and 3 went up in smoke also, so has anyone been through this? Sure could use the help on this. thanks
4x4 Bart
44
Mar 7, 2014 12:39 PM
Vinford
Nov 19, 2010 09:47 AM
gt250
Mar 11, 2007 08:24 AM
scar98
Electrical Systems/Wiring
Dec 19, 2005 12:46 AM
fordflaresides
Nov 12, 2005 06:57 AM
