1978 - 1996 Big Bronco
Oil Pressure Help
Old Jan 15, 2008 | 08:43 AM
Diesel Dave 04's Avatar
Diesel Dave 04
Oil Pressure Help
Ok i start the 351 powered automatic 92 bronco up cold 28* F I start down the road and i see the pressure gauge drop to nothing, Figured it was the gauge going bad like my other 92 has. So i keep going on to work cause i knew the oil was full.
3 miles down the road it starts to get noise so Now i know it is not the gauge it is in fact no oil pressure. so as i get off the road i hear a screeching noise then it goes away, ( I hope i didnt spin a bearing) then i shut it off wait 30 sec. and restart it and just like that it has oil pressure and the lifters pump up and all is well.
What happend???/ I thought maybe the drain holes were pluged and all the oil was up top but i feel in that case it would have been smoking do to oil getting past the valve guide seals. so my next thought is crud sucked up to the oil pick up.
What do you guys think? Am i on the right track?
This is a truck i use to plow snow it has 152K on it.
Can I get the pan out without pulling the engine 351 E40d trans?
I need some input thanks Dave
Old Jan 15, 2008 | 10:40 AM
Kemicalburns's Avatar
Kemicalburns
what oil are you running? 10-30?? i would still install a mechanical gauge to keep better track of whats going on.
Old Jan 15, 2008 | 10:52 AM
Diesel Dave 04
I can do that, but I know i had no oil pressure this time
Do you know if i can get the pan off with the engine in the truck?
It is 10-40 oil
Old Jan 15, 2008 | 11:35 AM
b4hntn's Avatar
b4hntn
AMEN! to Kem. Start with a mechanical oil pressure guage. I screwed a 1/4 X 6" brass nipple into the block then hooked tubing to it. Is the correct oil filter on it? I think it should have a bypass valve in it but not really sure. If the filter is plugged with cold oil the valve in the engine may dump it back into the crankase with limited oil flow through the galleries. Motorcraft filter seems popular in this forum for better flow and I use it. I went with Mobil Clean High Mileage 10W-30 to slowly clean without breaking chunks loose and plugging the oil galleries or screen.
Old Jan 15, 2008 | 12:20 PM
Diesel Dave 04
Does any one know if i can get the pan off with the engine in the truck????
Old Jan 15, 2008 | 01:17 PM
Kemicalburns
more then likely not. but you can atleast try by hoisting it up as far as possible. it will take some time for sure. ive heard if you get the pan loose and then remove the oil pump the oil pan will then come out.
Old Jan 15, 2008 | 08:04 PM
Diesel Dave 04
well it had oil pressure all the way home from work, I changed the oil and filter it looked like normal oil, Im lucky enough to have a lift in my shop at he house so i took a good look and it dont look like you can get that pan out with it in the truck.
Im going to try it with the new oil and filter and see what happens.
Old Jan 16, 2008 | 09:27 AM
alxsnmr's Avatar
alxsnmr
Supposedly if you take the upper intake off and take the oil pump loose you can get the pan out, but the E4OD length still cause clearance issues because it causes the valve covers to hit the fire wall before enough room is had in the truck.
Old Jan 20, 2008 | 12:17 AM
Surge08's Avatar
Surge08
I have a 88 bronco with a 5.0L. Had oil pressure problems and it had took out the main bearings and rod bearings. Ford is known for having problems with the 5.0 and 5.8 with oil pressure. If you look at your gauge it nomally sits on the N or the O of normal. When I replaced the crank and bearings I had upgraded the oil pump to a high volume pump. My oil pressure now sits between R and M of the gauge.
Old Jan 20, 2008 | 01:46 PM
351_wbronco's Avatar
351_wbronco
i have a 83 with a 351w in it and my oil pressure is at(65)cold and when it is warmed up it is at(45) and it has over 100,000 miles on it if not more it just trip to all (000000)
Old Jan 20, 2008 | 02:01 PM
helirich's Avatar
helirich
Someone on here awhile back said that the stock oil pressure guage is just an oil presure switch. Meaning its either on or off. (A higher reading is not higher pressure) I dont know if its true. BroncoChris's experince would seem to indicate that its not. I hope its not, but I wouldnt put it past them.
Old Jan 20, 2008 | 02:19 PM
351_wbronco
i have a aftermarket gauge in mine i put it in cause i don't trust the stock ones.
