Firewall swap
Old Jan 14, 2008 | 10:31 PM
ralf's Avatar
ralf
Firewall swap
The cab on my 85 F150 was eaten up with rust. A friend let me have a rust free 95 F450 cab. The cabs are identical except for the firewall. The 95 cab has a lot of the earlier cutouts sealed shut and lots of new openings. My 85 firewall is solid. I'm thinking of drilling out the spotwelds and swaping firewalls. Of course I will weld lots of bracing on my 95 cab before removing fire wall. Is this do-able? Any drawbacks? I am going to keep the 85 pretty much stock except the 3 on the tree will be replaced with 4 speed manual tranny with 4th being overdrive behind the straight 6.
Old Jan 14, 2008 | 11:56 PM
Franklin2's Avatar
Franklin2
If you are confident you have the skill, I am sure it could be done.
Old Jan 15, 2008 | 10:39 PM
ralf's Avatar
ralf
Not much skill, but lots of confidence.
Old Jan 15, 2008 | 11:14 PM
Redneck1465's Avatar
Redneck1465
Anything can be done as long as you have the patience and desire to get it done.
Old Jan 17, 2008 | 12:22 AM
82F100SWB's Avatar
82F100SWB
No need to swap the whole firewall over. All you really need to transfer over is the bracket to hang the pedal bracket from, and the rest can be easily fabbed from there. We swapped a 94 cab onto my buddy's 86 last summer, and that was all we did. The brackets that bolt the dash to the sides of the cab needed a bit of tweaking, but it was all done after we hung the dash from the pedal bracket. The only real big difference is that the newer truck has raised tabs along the bottom of the windshield that the dash bolts to where an 80-86 is flat. You need to deal with these so the dash cap will fit properly.
Here's the 94 cab with the 86 pedals hung and the heater partway installed.:
We did have some sheetmetal and hole saws handy to block off unneeded holes and put new ones where we needed them, but, we put the dash in and had the wiring run in an evening. We did the whole project in a a week of evenings and a weekend, including pulling the cab from the donor truck. We swapped in a 5 speed while we were at it, changed a couple cross members, and replaced broken engine mounts etc while we were at it. If we had of just been swapping the cab over, it would have been probably a 2 day project.
But, not everyone has the tools we have for lifting... LOL
kindorotten
24
Aug 21, 2016 10:18 AM
Bootlegger's Deluxe
15
Oct 17, 2015 10:07 AM
Built_Ford_Tough_757
Aug 9, 2015 12:25 PM
The Incredible Sloth
May 21, 2011 05:16 AM
quentinorciuch
Nov 22, 2007 11:35 PM
