Cold Morning Troubles
Old Jan 14, 2008 | 10:00 PM
houtsdg's Avatar
houtsdg
Driving a V-10 X. Has run great for the year I have had it. COuple of months ago, stalled on start and had to gas it to re-start. Had stalled once or twice on start since, but re-started and ran normal after. Last week, stalled on start and had to gas it to get it started and keep it running for about the first 10 minutes (Temp around 0). Took it to my friend who found it had a very plugged fuel filter and changed it. Ran fine until yesterday when it stalled and then had to gas to start and keep running, again for about 10 minutes. Friend suggested filling tank good and full and changing air filter. I did. Same problem this morning. THrough all of this, no CEL nor any codes when we scanned it. So, anyone have any suggestions? Injectors, electronic choke, fuel pump???? Thanks!
Old Jan 14, 2008 | 10:08 PM
X_Hemi_Guy's Avatar
X_Hemi_Guy
I suggest to check/clean the MAF and air filter...first
<A href="https://www.ford-trucks.com/lc/lc.php?action=do&link=http%3A%2F%2Fgood-times.webshots.com%2Fphoto%2F2027167960099735294Kk uRdn%5D" target=_top rel=nofollow>
Our 2V V10 has an IAC (Idle Air Control)…you may want to check that.
The MAF (Mass Air Flow sensor) may be coated with ‘stuff’ from years of uses...there is commercially available MAF spray cleaner...
Air filter clogged in need of changing?
I'd suggest a fuel filter change but you already did that!
Last option...check with the stealership to see if any PCM re-flash is needed?
Might you have some bad gas in the tank?
<O
That's all my ideas...I'm sure others can add more...
Good luck...keep us updated.
Joe.
<O
Old Jan 14, 2008 | 10:54 PM
i eat hybrids's Avatar
i eat hybrids
That is the classical IAC Valve going bad. My truck is doing the same thing. But its not as bad as ur truck (its in the beginning stages of heading south). Do u have to keep the pressure on ur gas pedal inorder to keep her running?
Old Jan 15, 2008 | 08:57 AM
houtsdg's Avatar
houtsdg
Yes, I do have to keep pressure on the accelerator to get it started and keep it running. At least until it gets warmed up to a certain point. Where is the IAC and how much is the part going to cost me? Thanks!
Old Jan 15, 2008 | 09:01 AM
X_Hemi_Guy's Avatar
X_Hemi_Guy
Do a search on IAC and I'll bet you will get step by step instructions on how to replace it...just a hunch...
Good luck!
joe.
Old Jan 15, 2008 | 10:16 AM
i eat hybrids
Ill post the instructions soon. If u need then fast, then go down to the v-10 forum. They have the instructions.
Old Jan 15, 2008 | 01:37 PM
i eat hybrids
https://www.ford-trucks.com/user_gal...&albumid=22274 their are the instructions. Hope this helps. Srry though, i dont kno how much they cost
Old Jan 15, 2008 | 03:50 PM
houtsdg's Avatar
houtsdg
Thanks for the help, guys. My friend is going to take a look at it again for me on Monday. Thank goodness for friends and the internet!
Old Jan 15, 2008 | 04:28 PM
i eat hybrids
Np, let us kno how it goes!
Old Jan 17, 2008 | 01:23 PM
houtsdg's Avatar
houtsdg
Quick update, here. I filled the thing full on Sunday + 2 cans of seafoam. On Tuesday am had the problem at 17f. Didn't drive again until Wednesday pm at 12f -- started and ran fine. Thursday am at 7f -- started and ran fine again. Any chance I cleared the line and/or injectors and solved the problem?
Thanks!
Old Jan 17, 2008 | 01:40 PM
i eat hybrids
Wait, what did u fill with seafoam?
Old Jan 17, 2008 | 02:30 PM
houtsdg's Avatar
houtsdg
The fuel tank.. isn't that were it is supposed to go???
Old Jan 17, 2008 | 09:32 PM
Toreador_Diesel's Avatar
Toreador_Diesel
FTE Leadership Emeritus
Yep, lol
Old Jan 17, 2008 | 09:34 PM
i eat hybrids
the reason why i asked, was that i have never heard of seafoam before.
Old Jan 17, 2008 | 09:37 PM
Toreador_Diesel
Go to wal-mart or autozone, it works wonders on a gasser. I ran 2 bottles through a company car at work and it was like a brand new car again.
