I have an 89 Bronco with an automatic transmission. I believe I have a Borg-Warner 13-56 Electronich Shift Transfer Case. I need to check the fluid level in it but the fill plug and the drain plugs are almost stripped out. I can tell that it takes some sort of square drive but I am not sure what size. I have tried a 1/2 drive (too big) and a 3/8 drive (too small). Is is metric or a different standard size? I do not want to try other things that might strip it completely.
its the 3/8s drive. you might have to use a drill and tap to remove them. just use liquid wrench and be sure to drain the fluid afterwards. I had this same problem then i went with an outy plug vs the inny
Yes, the plug size is for a 3/8" ratchet drive. If the square hole is stripped out too large where the 3/8" won't budge it, you can try grinding down an old/ cheap 1/2" drive ratchet until it fits snugly. I also recommend replacing the plugs with the type that has the square center sticking out, so you can get a regular wrench or Crescent on it in the future. JSM84
Thanks for any help.
I have a 3/8 machine key in my tool bag I use for those so I can get a wrench on it instead. If there's still enough meat on the flats you might try either the 3/8 or stepping up a size to try to get it out.
I just did this on my '91 with the 1356. I used a cold chisel on the drain plug and worked it around until it unscrewed. The level-check plug I had to drill out. Replaced them both with brass "outies" from Lowe's.
Don't put the plug back in with air ratchet. I made a small crack in the flange from overtightening. which leaked. Cost me an extra $75.00 to repair when I had the transmission rebuilt.
If I drill it out I am worried about getting metal shavings inside the transfer case. Any tricks that might prevent that?
What I did was I drilled it larger and larger, one step at at time, but did not let the nose of the bit break thru the very back of the plug. Then I used a sharp chisel to collapse the sides of the plug since they were now very thin. When I did that, I was then able to unscrew the remainder of the plug.
