rims
Old Jan 16, 2008 | 03:16 PM
fordcountry's Avatar
fordcountry
Originally Posted by 71-4R3SONS
Key word in this is OEM (take-offs). Yes, they'll bolt right up to your 05 X, but, they will rub without the spacer/adapters.
71-4R3SONS,
Do they rub all the time or only when turning? Could you get away with it by not turning the wheels a full turn? Just curious.
Old Jan 16, 2008 | 05:39 PM
71-4R3SONS's Avatar
71-4R3SONS
Originally Posted by fordcountry
71-4R3SONS,
To be honest with you, I did not turn the wheels when I test fit one front wheel/tire without the spacer/adapter. Just looking at it, I knew that turning (not even to lock) would cause major rubbing. Since you can't "skid steer" with your X's brake system, I'd highly recommend against mounting the combo without the ability to steer "lock to lock".
Old Jan 19, 2008 | 11:52 PM
97REDPSD's Avatar
97REDPSD
Thanks for the info guys !!!! I will try them on before I buy. Their 20" rockstar rims with good tires on them.
Old Jan 21, 2008 | 10:59 AM
fordcountry
Post some picture if you get them!
