Exployer 4.0 Intake noise
Old Jan 13, 2008 | 08:15 PM
jwright851's Avatar
jwright851
I have a 2001 exployer 4.0 that suddenly started missing real bad and I am getting codes 301 missfire and rich on bank 1 lean on bank 2, it is showing miss fire on all but one cyl, 5 i think it was. I have pulled the exhaust off at the manifolds, someone told me it was the cat. converters, not it. I have replaced intake gaskets upper and lower, not it. It has a loud chirping sound that sounds like it is inside the intake manifold, a constant chirp, I have spent all day looking for vacum leaks but have found none. thanks in advance if any one can help
Old Jan 13, 2008 | 09:30 PM
antony25's Avatar
antony25
Try unplugging the camshaft position sensor located behind the intake and see if it runs any different.
Old Jan 14, 2008 | 07:12 PM
jwright851's Avatar
jwright851
I have found the problem. broken exaust valve spring, ran compression check cyl.#1 had no compression and pulled valve cover and seen broken spring. Hope this helps someone else having same problem. thanks for answering
Old Jan 27, 2008 | 04:41 PM
spirit's Avatar
spirit
Check and clean your IAC valve- that make a loud noise when it acts up!
