I checked my owner's manual about the dual fuel tank operation and all it basically said was to make sure one tank does not go completely dry before switching. Does that mean I can switch fuel tanks on the fly? I didn't want to try it until I got some other folks' opinions.
pumps cost ~$200 they do not like to be run dry it only takes 3 or 4 times before there out puts are reduced. The gas cools the pumps no gas you end up over heating the pump.
I've run both my Fords dry on several occasions and they still pump fine- on a gas motor. On a diesel DON'T run the tank dry- air in the fuel system of a diesel is a real PITA to deal with.
Mine is a diesel and that's the main reason the OM said not to run the tanks dry. But it's nice to know that I can switch my tanks any time. Thanks for all your guys' info!
I used to run my tanks dry before switching all the time with my gas truck. Never had a problem.
Have run the diecel dry on each tank just to see what happens & how much fuel they hold.
Haven't hurt anything yet. Switching on the fly is absolutely ok.
For some strange reason, my front tank reads empty all the time and no matter how full I keep the rear tank, it always reads 3/4 or less.
I just gave up and have been running off of mileage for over a year now. When I fill the tanks, I write down my odometor reading. Then I add 180 for the front tank (19 gal.) and 160 (18 gal) for the rear. I use these markers for the time to switch and I always do it while I am driving so if it quits, at least I can roll over to the side.
So far, so good.
Not 100% positive if your truck has them but it's possible that your flow meters are bad. Usually they are in the gas tank. The flow meter on my Firebird has read 1/4 tank high since I bought the car 5.5 years ago. Unfortunately, to get to the fuel tank on the 'bird you must drop the rear axle. So until I either swap rear axles or have to change my fuel pump I just use my trip odo for fueling.
From what I have seen in these posts over the past year, my fuel issues are par for the course. I am just not ready to drop the tanks at this time. My past trucks were Internationals and GMC's so I am used to running by mileage. I must say that I am thankful for a working odometer as it beats the stick I used to use on the '62 GMC pickup.
Lol. i hear ya. the fuel guage on my '80 GMC dump truck doesn't work either. It has 2 tanks and I'll be using a stick to check them once I get it back on the road.
we used to have the old chevy with the tank behind the seat i remember my grandfather tapping on it up and down to guestimate the fuel levels
looking back on this how nuts was it to have the fuel tank in the cab with the passengers, but this was also when kids ALWAYS rode in the back of the truck adn never had a helmet on the bicycle
And we had fewer fires then when they moved the tank to the back open to rear end crashes or put it under the driver outside the frame.
Yup haveing it protected in the cab was a stupid idea.
