Sponsored by: Real Truck
super chip trouble
Old Jan 13, 2008 | 02:29 PM
farmer ford's Avatar
farmer ford
Thumbs down super chip trouble
i have a '95 ford F350 4x4 with the super chip tuner. when the tuner is in tow performance or high performance it surges at an idle throws codes when i get over 3000 Rpm. i took it to a local shop and they said they changed the fuel pressure control relay on the high pressure oil line. it did not help and i am very frustrated. any ideas?
Old Jan 13, 2008 | 05:21 PM
redford's Avatar
redford
FTE Leadership Emeritus
Is this a diesel engine?
Old Jan 13, 2008 | 06:06 PM
farmer ford
it is diesel
Old Jan 13, 2008 | 07:35 PM
UP_There's Avatar
UP_There
does the truck run okay when the superchip is in stock setting? I would be contacting Superchips right away if it runs good in stock
Old Jan 14, 2008 | 09:00 AM
farmer ford
i called superchips and they said their programmer has now control over thes settings???? it felt like a run around
Old Jan 14, 2008 | 11:31 AM
redford's Avatar
redford
What codes are you seeing?
Old Jan 14, 2008 | 10:31 PM
UP_There's Avatar
UP_There
your program should be completely STOCK with the Superchip program removed. Sounds like something else might be going on.........but you never said if it does the same thing in stock setting?
