fuel pump wont stop running
Old Jan 13, 2008 | 01:27 PM
tonfro's Avatar
tonfro
I am looking at a 90 f150, 4.9, 4peed to buy. One fuel tank
The guy said he put new fuel pump on and to get it started the pump has to run for at least 30 seconds.
When I get there it wont fire up. The fuel pump keeps running. The truck had less than 1-4 of a tank of gas. owner put 2 gallons in truck but the pump kept running.
The only thing I can figure is the pump pickup has broke off.
Or the pump cant raise the pressure high enough.
I guess it could also be a clogged fuel filter.
Does anybody have a suggestion?
Didnt have tools and manual for the 90 f series.
thanks in advance
gt
Old Jan 13, 2008 | 01:43 PM
Conanski's Avatar
Conanski
Most likely issue is the fuel pump relay is shorted, it's located on the drivers side inner fender. When the key is turned to on(not start) the pump should run for a second or 2 and stop, and it should run continuously with the key in the start position or once the motor starts, but it'll be harder to hear. This is all controlled by the ECU, so if the relay is not shorted and there are no other wiring shorts in the pump circuit, you may have an ECU problem.
Old Jan 13, 2008 | 01:49 PM
quicklook2's Avatar
quicklook2
classic sign of a bad computer (ecu).
Old Jan 14, 2008 | 03:36 AM
tonfro's Avatar
tonfro
So, if I got this right.
The ECU controls the spark?
So, if I squirt some starting fluid into the air filter and IT does fire
would that mean the ECU is good?
How can the ECU be checked out?
Thanks in advance.
gt
Old Jan 14, 2008 | 11:37 AM
quicklook2's Avatar
quicklook2
no, it starts because of the starting fluid.
you need a new ecu.
Old Jan 14, 2008 | 12:14 PM
DJdemon6696's Avatar
DJdemon6696
does it starts and idle rough? with chek engine light?
nway but mine is doing diss and its the ECU.. im looking for a new one soon..
the fuel pumps are timed by the ECU.. it does not work with pressure or anything else exept if the relay is shorted.. it will runn all the time without stopiing
i recomend you chek the relay if its not that then its your ECU
Old Jan 14, 2008 | 03:13 PM
FORD4POWER's Avatar
FORD4POWER
Check the Tan wire with a green tracer on it. It is probably grounding out some where.
Old Jan 14, 2008 | 05:02 PM
subford's Avatar
subford
It has a bad computer.
You will have spark with the computer removed and it will fire on starting fluid.
Boodrow379
Apr 24, 2014 09:24 AM
dustybumpers
21
May 20, 2013 07:05 AM
78 Ford F150 460
17
Jun 24, 2012 11:31 PM
4beatg8
Jun 17, 2008 11:13 PM
Burple
Jul 1, 2002 12:23 PM
