Sponsored by: Real Truck
hubs wont unlock
Old Jan 13, 2008 | 06:19 AM
derekmcnew's Avatar
derekmcnew
hubs wont unlock
my manual hubs will lock in but will not unlock but work fine when i pop them out & work them in my hand . i have a 99 sd. anybody had a set apart?
Old Jan 14, 2008 | 08:56 AM
dagren99's Avatar
dagren99
Hubs
Just had mine off this last weekend - the Ford manual hubs can be a little sticky if not used very often. Might want to check to see if your axle has any play in it - either in and out or, up and down. A little wobble may be causing the hubs to bind up. If all looks ok here then try a light film of grease on the axle stub splines - this may help.
It sounds like it may be time for some new (Warn) hubs.
DG
Old Jan 14, 2008 | 11:25 AM
redford's Avatar
redford
FTE Leadership Emeritus
When were they last lubricated?
Old Jan 14, 2008 | 06:19 PM
derekmcnew's Avatar
derekmcnew
thanks guys i lubed them up good & everystuff like that before i asked for help on here i figured it needed an aftermarket set but i was curious if anyone had a set apart.when i get my aftermarket set im gonna dig into oems just to see how they work
Old Jan 14, 2008 | 07:53 PM
viperbluelx's Avatar
viperbluelx
Originally Posted by dagren99
Might want to check to see if your axle has any play in it - either in and out or, up and down. .
what's the fix for this if you already have a new hub?
2002exPSD
Aug 26, 2016 06:42 AM
ruger761
Jun 4, 2012 10:24 PM
swann79
Nov 2, 2007 12:54 AM
jopiel
Oct 5, 2007 08:29 PM
saffordstud
Feb 12, 2007 04:53 PM
