Aerostar Ford Aerostar
How to adjust rear brakes
Old Jan 12, 2008 | 05:23 PM
Bax2008's Avatar
Bax2008
'95 XLT
Just replaced my brake shoes and am wondering how to adjust them.
I already got them close through the adjustment access hole.
Do these adjust further with the e-brake handle or with backing up and braking?
I did a search and found BOTH recommended in one thread??
Thnx.
Old Jan 12, 2008 | 08:33 PM
xlt4wd90's Avatar
xlt4wd90
Try both, and see which gives you the firmer pedal feel.
Old Jan 12, 2008 | 09:24 PM
Bax2008's Avatar
Bax2008
Not quite the specific answer I was looking for.
Old Jan 12, 2008 | 10:08 PM
96_4wdr's Avatar
96_4wdr
thru the brake adjust. hole with a spoon brake wrench
tight and then back off until wheel spins with little brake drag.
have to seat the shoes in since all rear shoes for Aero are organic or semi metallic. 10 hard stops from 40 mph to 10 mph in succession, release brake between each cycle...park and let brakes cool off.
check adjustment by same technique above.
brakes will not reach full efficiency for 50 to 100 miles.
e brakes last, adjust for even cable pull on both sides.... 2 to 3 clicks up until full lock
self adjusters on Aero seldom work right and i don't rely on them for my passengers safety
Old Jan 12, 2008 | 10:15 PM
Bax2008's Avatar
Bax2008
Thank you!
bill11012
Aug 5, 2019 11:52 AM
rbr658
Jul 15, 2015 11:34 AM
neumannfamily
Apr 12, 2009 10:11 PM
Tenderpaw
Nov 11, 2008 11:34 AM
DAV1972
Aug 30, 2008 07:57 AM
