289 remote pump
Old Jan 12, 2008 | 03:20 PM
finnly56's Avatar
finnly56
Question 289 remote pump
I want to install a remote water pump on my 289 to reduce drag on my crank and make room for an electric fan, cause space is very limited between my pump and rad.
And I have plans in the future to swap in a 600 HP S.B. engine.
2 Questions.
What G.P.M. of pump would be sufficient to cool 600HP?
Where could I find the "AN" fittings to bolt onto the engine block, where the stock water pump used to be, that would be large enough to accommodate the pump as well?
Thanks
Old Jan 12, 2008 | 04:03 PM
85e150's Avatar
85e150
These are only for drag racing, as they won't last for long.
http://www.racingjunk.com/post/68613...ater-Pump.html
British outfit that seems to have pumps for longer term use:
http://www.thinkauto.com/waterpumps.htm
Another:
http://www.stewartcomponents.net/Mer...Code=ElectPump
More:
http://www.jegs.com/webapp/wcs/store...10135_-1_10131
And there are more, many look like they bolt to the front of the motor.....4.6 and Chev is all I saw.
Google youself and find them......
Good luck.
