Some white smoke...
Old Jan 12, 2008 | 12:47 PM
whodatt's Avatar
whodatt
Some white smoke...
I have not started my truck (07 6.0, approximately 16000 miles) in about a week and a half, and yesterday when I did I noticed a good bit of white smoke coming out of the exhaust for about ten seconds, then it stopped. Everything else seemed fine.
I have changed the oil myself at 1,000, 5,000, 10,000 and 15,000 miles. Never any issues or problems. I also changed the fuel filters about 500 miles ago and that also went very easy with no issues. I have no mods to truck at all, other than the high idle mod which I did at about 1500 miles and also have not chiped it.
No other problems that I could detect, and the smoke disappeared totally after about ten seconds. I did notice this once before at about 8000 miles, but I attributed that to a very cold day.
Is this something normal, or should I be taking it back to the dealer?
Old Jan 12, 2008 | 01:37 PM
doubledee715's Avatar
doubledee715
normalllllllllll
Old Jan 13, 2008 | 07:03 PM
Mustangbru8's Avatar
Mustangbru8
that sounds fine
Old Jan 13, 2008 | 07:38 PM
tolliewolly's Avatar
tolliewolly
Dont worry. Mine is white for a few minutes everyday when I start it up. You can see a little while smoke as it warms up. I hope its ok! It runs great all the time but just when it starts up it likes to put out a trace of white smoke for ten minutes.
Old Jan 13, 2008 | 07:57 PM
tex25025's Avatar
tex25025
It is normal if it clears up not long after. Cold days especially get that, I know with my tractors they'll smoke for awhile especially on a cold day and then they'll clear right on up.
Old Jan 13, 2008 | 08:01 PM
tolliewolly
Yea I hope I dont have a problem. It smokes for a while and it is very little but you can see the little bit of white coming out of it as it idles.
Old Jan 13, 2008 | 09:26 PM
slowmans's Avatar
slowmans
totaly normal just a little moisture, throw some powerservice in you tank on a regular basis to help with lubrication and to rid any water in your fuel, I run b-5 and the truck runs soooo much smoother and quieter!!!
Old Jan 13, 2008 | 09:39 PM
tolliewolly
Where do you get powerservice and what does it do?
Old Jan 14, 2008 | 11:18 PM
F250tuff's Avatar
F250tuff
Walmart or truckstops.
It adds lubrication for the injectors, increases the cetane level, may increase fuel mileage (didn't appear to help mine), and does a few other things.
The winter formula (white jug) prevents fuel gelling.
Here's a link for each of the formulas:
http://dev.powerservice.com/dk/
http://dev.powerservice.com/dfs/
Old Jan 14, 2008 | 11:30 PM
zrt600guy's Avatar
zrt600guy
I have been running the Ford cetane booster in the warmer weather, and the anti-gel cetane booster in teh cold weather, and I think I like them more than the Power Service Diesel Kleen. Truck seems to run better, plus I think you use less of it per tank so you only need a smaller bottle in the truck. Not sure which is a better deal price wise, especially when you start considering some dealers will sell it wholesale to you, others want full retail. I hate that!
Old Jan 19, 2008 | 09:37 AM
whodatt's Avatar
whodatt
Thanks for all the replies. I guess I don't have to worry about it anymore.
As a side note, I have been using the power service additives since I bought the truck, so I really don't know how it might be without it. Getting around 17 when driving it locally, and about 20 when it's all highway driving.
Thanks again.
