? on the commander
Old Jan 12, 2008 | 10:07 AM
1highStroke's Avatar
1highStroke
? on the commander
Has anyone used the commander with the Dp chip or used the commander as just a stand alone gauge system. I am just wanting to get some info on how accurite they are compared to analog gauges. Thanks for any imput.
Old Jan 12, 2008 | 07:30 PM
F350-6's Avatar
F350-6
I'll bump you back up to the top. Maybe someone knows.
Old Jan 12, 2008 | 08:00 PM
jeff7825's Avatar
jeff7825
I actually just put a commander in my truck today. I plan on using it as a stand alone gauge. I don't really know how it compares to other gauges, as I have never had other gauges. Seems like it is pretty accurate so far. But I haven't really driven with it all that much yet.
Old Jan 12, 2008 | 08:54 PM
DP-Tuner's Avatar
DP-Tuner
PREMIUM SPONSOR
It will not control the f5 chips.
Diane
__________________
Jody & Diane Tipton- DP-Tuner®
FTE Legacy Sponsors since 2006
Custom tuning for 7.3l, 6.0l, 6.4l,6.7l, Ecoboost,
Get Tuned! 828-221-0076 ext. 802
Become our Facebook Fan
Old Jan 12, 2008 | 09:04 PM
F350-6's Avatar
F350-6
Diane
Well that's the best answer your going to get considering the source.
Old Jan 13, 2008 | 12:25 AM
kupaa's Avatar
kupaa
i had the commander just for the gauges but sold it for the edge evo2 but now someone want to buy it from me so now i am thinking i might buy some analog gauges.I no that the two gauges dont read boost correctly but it is real nice to have all that features that the evo provides.
Old Jan 13, 2008 | 02:29 PM
1highStroke
jeff let me know how it works out for ya. I've heard from other ppl that the boost isn't correct when you use a boost foiler
Old Jan 13, 2008 | 11:03 PM
jeff7825's Avatar
jeff7825
I'll be sure to let you know. I don't have one of those annilators on my truck, but the boost readings seem to be pretty accurate so far.
Old Jan 14, 2008 | 10:25 PM
Dually77's Avatar
Dually77
“Good judgment comes from experience, and a lot of that comes from bad judgment.” Will Rogers
Quoting my great uncle.....cool
Old Jan 14, 2008 | 10:37 PM
kupaa's Avatar
kupaa
it will only go to 18-20lbs because it is taking a reading from your pcm,you have to get a signal from the map sensor to read correctly.
Old Jan 15, 2008 | 06:51 AM
1highStroke
is there anyway to get the reading from the map sensor with the commander?
Old Jan 15, 2008 | 08:23 AM
jeff7825's Avatar
jeff7825
Mine hooked up to a wire on the map sensor.
Old Jan 22, 2008 | 11:18 AM
Dually77's Avatar
Dually77
I just intalled my commander and removed the analog gauge and couldnt be happier. You need to piggy back the wire in the center of the MAP plug and if you have a foiler you would just connect to it in the same location. So far the cammander is within 2lb of what the analog gauges were.
Old Jan 22, 2008 | 12:26 PM
MTDewX's Avatar
MTDewX
seemed to work for me so far. dont use the chip that is an optoin. seemed to screw things up, and the fuel presure is not consistant, but I really dont use it for Diesel psi. when I am on VO is when I need it to read right.
I think said and done and not ever using the other gauges and I were buying again, I would get the analog ones. but since I have what I have I am happy with it thus far.
Oh, the buttons sometimes dont work, so you have to take it apart to clean the contacts. but I dont change my setting ususally once its going.
